vw4life
Hi Folks,
I have found uneven tire wear on my right side, inside shoulder of my tires. I first noticed this problem 4 years ago and spoke about it here.
Now that I have gone through one set of tires, put on a second, and pulled them off for winter I have definitively observed that my front right tire is wear excessively on the inside shoulder.
I have always found my car to pull to the right. Any tech or guru that drives it briefly says the alignment is perfect. I even had an alignment checked- they printed it out and it shows the major dimensions are pretty good. Alignment jpg here
So I have this long term subtle tirewear- I am getting only 60-70,000 km on a set of tires instead of the 80,-100,000 km I should get and it is clearly evident there is uneven wear.
I keep the pressures about 35-38 PSI so even if over inflated I assumed I would get excessive wear in the center, not the shoulders.
It is suspect to me that I have always noticed this subtle pull to the right and now it is clearly manifested in tire wear. All the digital alignment checks say nothing is wrong? I have also noticed this issue since I owned the car (since 20,000km , now 110,000 km) so I don't think it is a ball joint wear issue - unless there is a control arm/joint issue that was pre-existing.
I did find this thread on the subject interesting. I guess I need an alignment guru?
What do I do?
What do I do?
