BASICS:
the VNT turbo boost is controlled by opening or closing the vanes on the turbo - vanes fully open means least possible boost, fully closed maximum possible boost. the actual amount of boost it will make depends on the turbo characteristics (size, flow etc), rpm and amount of fuel being burned. on a wastegate turbo the wastegate is fully open for least boost and closed for maximum boost.
the n75 controls the vacuum to the turbo VNT actuator. it's a dumb device - a simple valve that is controlled by the ECU (and the "tune") to open/close vanes a certain amount to achieve desired boost. open the vanes fully for least possible boost by passing no vacuum (valve 100% closed) or close the vanes for maximum possible boost by passing 100% of the vacuum (valve 100% open). it doesn't really know how much vacuum it's passing, it's simply opening and closing a valve to let 0 - 100% vacuum through it.
HOWEVER, it does seem that the N75 valve does have a regulator in it - which is set to 25HG according to a brand new pierburg which i just tested. which makes sense for fault tolerance. if your vac supply is 25+ HG your vac supply should probably be good enough. if it's lower than that there will be issues. the % duty cycle reported in vcds should reflect the exact amount of vacuum multiplied by 25hg. so 20% would mean 80% n75 valve open, so a healthy system would show 20HG to the actuator with 20% duty cycle (alh).
in VCDS for EDC15 ALH cars the n75 value shows the percent the VALVE is CLOSED. so if you see 100% that means 0% vacuum is being passed -valve is fully closed, not passing any vacuum through, so vanes wide open, least boost. 0% means valve is fully open, full vacuum, for max boost. for MAS15 (wastegate cars - AHU) and EDC16 cars (BEW PD cars in the US) and EDC17 (common rails), the n75 values are reversed, the n75 value shown is the percent the VALVE is OPEN. so 100% means 100% vacuum being passed through n75 and vanes fully closed (or for wastegate, the wastegate is 100% closed) for max boost.
AFAIK, a healthy 1.9tdi should put out 29+ HG. after fixing the common wiggly vac pump nipple on an alh, the few i've tested are all show 29.5 HG vac supply. both my AHUs also show 29.5ish. the leaky nipple can easily cause 1-4HG lower vacuum from what i've seen.
the amount of vane closure needed to make XXX amount of boost depends on the turbo characteristics, RPM and fueling. start of injection (SOI) will have a large affect on that as well, not just the quantity. and optimal SOI will vary depending on the pump (eg 10 or 11mm) and the nozzle size as well nozzle/injector wear. generally, as rpm increases, less vane closure is needed to make desired boost.
ROD LENGTH:
AFAIK, factory "rod length" for vnt15 and vnt17 cars is such that when applying 18HG the vane lever will hit the set screw stop for maximum vane closure. with 0HG vacuum the lever is hitting the other INTERNAL stop in the turbo for vanes wide open. if rod length has been set too short, the lever may not hit the vanes-fully-open position. you can't see the stop but you can feel it if you disconnect actuator from the lever. the actual HG setting of when it hits the set screw is a little arbitrary - but the important thing is that it is in a range so that it will hit both stops for full vane movement. too short - may not allow vanes to fully open. too long, may not fully close vanes. if the set screw has been altered from factory, it will throw off the reading of how "long" the rod is. so if set screw has backed out a couple threads, if you set the rod length to 18HG, it will now effectively a couple turns shorter than that. where rod length is set is calibrated for the tune.
the set screw is a physical safety stop - regardless of the tune, vac supply, hardware malfunctions, it will prevent the vanes from going beyond the specified amount of closure. you could remove the set screw completely and be perfectly fine --- IFF your N75 valve is 100% perfectly functioning, VAC supply is perfect and never goes above the max HG, and the tune is also done right.
it depends on the tune of course, but the vanes should rarely ever need full vane closure. only at very low rpm should the lever ever come close to or hit the set screw. but this really depends on the characteristics of the tune - namely how much boost it's wanting. if your fueling is correct, at 3000 rpm for example, and you are requesting 38mg fuel (stock max alh fuel), and you close the vanes 100% bad things will happen
TUNE:
so... in summary - the N75 is a "dumb device" - simply passing 0-100% vacuum through (but BEGINNING from 25HG or whatever the max is, say you have a leak and its 24HG), where the rod length is set and the amount of vacuum supply is critical to well performing boost control.
in the "tune", factory or otherwise, there is a pre-control map that is used to calculate how much to close the vanes to achieve desired boost. when you first press on the go pedal it makes this calculation and uses this map along with the PID controller and current conditions to determine where to go from there. so if you are at 2500 rpm and press the pedal to command 30mg fuel and 1500mbar of boost, say the tune makes a calculation of wanting n75 to be 40% initially. if the rod length and vac supply are all at factory spec, the tune is perfect, and all other hardware good - you should get perfect boost control. it generally will close vanes quickly to a certain degree and open them up as RPM and boost increases and target boost is reached. but if your vac supply is lower than 25HG, the n75 being a dumb device, 40% isn't going to close the vanes as much as with full factory spec vac supply. if your vac supply is 23Hg, 40% now is more like 42%. so the "first guess" to vane position by the ECU will be a little "short", so it will lag a bit and the pid controller adjusts. vanes will hang closed a bit longer. because this all happens so fast, it will then often cause an overshoot in boost and pid controller now ends up opening vanes, often overcompensating depending on exact conditions, so it may dip below target and then recover.
if rod length is longer than spec, it will have the same affect as low vacuum supply. pretty sure all this stuff is linear. if your vac supply is a bit low, shortening the rod a bit (as long as it still hits the full-open internal stop) would likely cure any boost issues.
in an aftermarket tune, the problem of n75 being off (vac supply low, rod length off etc) is often exaggerated. this is partly due to the pid controller maps relying on fuel consumption for the calculations. pretty much all ALH tunes people have (malone, kerma, rocketchip etc) all using the factory alh fuel quantity value range of 0-51mg. but if you add nozzles or 11mm pump, your fuel quantity range goes up quite a bit. 11mm and .230s can flow 80mg no problem. so in your tune, 45mg may actually mean 58mg fuel and 51mg means 80mg. so any maps the tune uses that rely on accurate fuel consumption are now not going to work right. your MFA cluster won't read fuel consumption correct, MPG readings will be off. you can calibrate it so that it's generally correct, but of course it will never be 100% over the full range of rpm and fuel. but for average driving over a whole tank, fudging the calibration likely will give a decent consistent result.
fuel consumption values now being off because the fueling is squished into the "0-51mg' range means boost control won't work as well as it should/could. different turbos also have different pid controller maps matched to their physical characteristics. larger turbos spool a little slower, but have more inertia. the calculations needed for good boost control are pretty different. lots of tuners use the same vnt15 pid controller maps regardless if you have a vnt15, 17 or a 17/22. so if you have a 17/22, boost control is going to be even worse. sometimes it's possible, errors in calibrations or current conditions can cancel each other out and it may perform well enough. very tricky to sort that out.
so you should now see that the n75 values in the tune are directly tied to your vac supply and rod length. a tune is calibrated for a certain amount of vacuum and rod length. up until a couple years ago, i didn't really fully grasp it all myself, especially the simplicity of it. if vac is a bit low, it may be good enough for a factory vnt15 tune. factory tunes run way more boost than necessary, so if you have some boost "lag" or dont' always meet target, it may not even smoke depending on how much fuel/rpm etc is happening and still drive decent. and the vnt15 is a very responsive turbo so pid control works well enough.
the same thing goes for other tunes. it may generally feel good if you have only 23HG vacuum or rod is a bit long. you would probably get the feeling it has some lag and overboost. depending how much it's off, you may get huge overboosts, spikes followed by big drops in boost. totally depends on the tune, hardware, and how much things are off. if you were to look at boost logs, you would certainly see big problems. if you managed to get vac/rod length perfectly calibrated to the tune, it would definitely perform better. but it's really dependent on the quality of tune you have and how well it's matched to your hardware. there are a LOT of tunes out there that people think are running great, but in fact, doing quite poorly but it's got more fuel than stock so it feels good and maybe MPG are decent enough... and the boost map is probably pretty lean, so the big dips may not cause too much smoke. results vary quite a bit....
-injection timing also plays a HUGE role in how well the turbo boosts as far as how much vane closure is needed to make boost...
-deleting EGR affects timing as well as boost control/N75 (from what i've seen so far, bigname PRO tunes don't account for this whatsoever)
-where the QA is positioned (hammer mod) plays a big role in how well fuel is calibrated.
-lots of bigname PRO tunes aren't nearly as well matched as one is led to believe esepcially with timing/fueling
-between fuel quantity, injection timing, vacuum/rod length issues, little boost leaks - the amount of error compounding going on can be great. sometimes, a comedy of errors produces something that actually runs OK or even decent!
hopefully i haven't made an errors in this, if so, please point them out
