Hey All,
I bought my used 2009 Tiguan TDI (2.0L, 4Motion, 103kW) which had an undersized battery installed. Before I discovered it was undersized, it was borrowed by someone who experienced a dead battery, and replaced it with the same undersized battery. Now I have this near-new battery:
* Yuasa DIN53LH which has 500 CCA and 55Ah capacity.
I discovered that the correct battery should be:
* Yuasa DIN65LH which has 680 CCA and 68Ah capacity (or equivalent, up to 740 or 800 CCA)
My question is: how BAD is it that I have this undersized battery?
This Tiguan TDI starts easily: and fires up after 2 to 5 turns of the crank, but it does seem to crank rather slowly. It has done this since I had the car, so i'm not sure what to expect, but my Touareg TDI cranks much faster with its massive 95R battery.
One thing I observed, is an issue where the TDI engine will turn over, fire up twice, and immediately quit. The engine runs for 1/4 of a second and quits. It doesn't do this when it's cold, but when warm, it usually does this once or twice, then it starts up normally. The car runs perfectly well otherwise.
Has anyone observed this issue (engine fires up and immediately quits)?
I was wondering: could it be because of the undersized battery?
That is, if the starter-motor doesn't get enough power, it struggles to properly turn over the (high-compression diesel) engine, and fires up, but barely, and can quit randomly. Once running, it doesn't quit, only quits immediately after startup. That's why it seems like an issue with battery + starter-motor.
I'd love to know if anyone out there can provide some insight.
