2footbraker
Anybody know a part # or make-up of the thick coating used on the underbody of later model VW's? I'm thinking specifically of the layer under the finish coat that appears to be "brushed" on. Thanks for any info.
The stuff I pictured above was recommended to me by two body shops, and in the grey color was almost an exact match in color and texture as OEM stuff on the underside of my 2000 Beetle. After I welded in a patch in the floor, I scuffed up the surrounding coating, and the seam sealer blended right in and seemed to adhere well to the 16 year old original coating. FWIW.so when he said 'brushed' on, I think he meant the textured undercoating of the entire floor.
My brand new Mercedes Sprinter has seem sealer clearly applied by a brush by hand in various places. It is most certainly not the work of a robot.seam sealer is NOT brushed and hasn't been since the early 90s. seam sealer is applied robotically and remains untouched after assembly, whereas on old cars they used to brush it after application.
The textured coating on the rockers is a different product again...that is gravel guard, and it is sprayed on.I'm looking for the rippled coating over the rockers. I want to repaint a couple spots on the pinch welds that were damaged by a jack before rust sets in. I appreciate all the responses. Would they use seam sealer on such a large area?
I got the seam sealer at CarQuest and the Gravel Guard was on sale as Napa (The professional quick dry stuff that's paintable). Just go to the autobody section of one of the big auto parts shops and they'll have everything.Rembrandt, where did you buy that stuff?
that's possible, guess if you can't get a tight panel fit, you fill it with seam sealer. Most companies have moved away from hand brushing seams since no two cars came out the same, robot applies SS, panels sqeeze together, and that's it. Working in auto production I get to see this stuff first hand.
OP, you need undercoating or seam sealer? What are you trying to do?
