Under Hood DPF Regen System Always Running
Mass. Wine Guy
Ipswich, Massachusetts
5-speed, 2015 Golf S 6-speed manual; 2015 Golf Sportwagen SEL 6-speed manual
2015 Golf Sportwagen 6-speed manual, about 140,000 miles. I took a trip from Massachusetts to Nova Scotia, including a ferry. While driving back through Maine today I pulled over to do some things and the DPF system that runs after the engine turns off came on. I’ve seen this many times. It’s on briefly then goes off.
When I started up a CEL came on. Driving performance seemed fine. But now that I’m home the radiator fan keeps running, turning off, then running.
I’m not technically knowledgeable, but obviously this has to do with something in the DPF/emissions system.
What should I do first? I’m within the Dieselgate warranty period. Is my battery going to go dead because of this?
Thank you very much.
Beewi
Commonwealth of Kentucky
2013 Jetta Sportwagen
If you're within the extended warranty, my understanding is that everything emissions equipment related, and almost everything that talks to the emissions equipment, is a covered replacement/repair. May want to take it in to your local dealer and see what they read. Just mention you think it's covered in the phone and they'll be able to verify by vin.
You mentioned your golf has 140k mi on it, but do you know when (or if) the DPF has been replaced most recently?
Beewi
Sorry that it managed to kill your battery... I'm a noob so bear with me for a second:
The fan is supposed to kick on when the car runs an "active" regen cycle to burn off the organic matter in the DPF, and does so to keep everything cool. If your DPF was really good and clogged with ash it and the car was trying to regen constantly in a futile attempt to clear it out, I would have thought you would get a DPF specific dash light, and the car would potentially be driving poorly. Is your tail pipe clean or do you get soot residue on your finger if you run it on the inside of the pipe?
If instead you have a faulty temp probe sending a "it's hotter than the sun in here!!!" reading to computer, the car may be running the fan thinking everything is going to melt if it doesn't. I had a temperature sensor on my engine freak out and throw crazy high numbers at the computer after a glow plug and glow plug module replacement. But in that case, my car threw both a CEL and a flashing glow plug light.
Mass. Wine Guy
I think you’re on to something. My fingers don’t get any soot from the tail pipe. And no dash light specific to the DPF. From what you say, temp sensor seems likely. Is there a ton of labor involved to change it?
The only dealer I trust at all is Portsmouth VW about 40 minutes from me. I’ll try jumping the battery and if it works I can get it there.
Thanks SO much!
Beewi
Don't thank me unless I'm right. Definitely call the dealer you trust ahead of time, and let them know you think it will be warranty work. I have no idea about book time for individual sensors. We're all just spitballing until you can get a scan tool on it.
Beewi
VCDS is still around $200 for unlimited service on 3 different VINs. Even if this car is the only one you'll ever scan with it, what's the price the shop will charge for an hour of diagnostic time on top of the hassle and cost of driving the car there and back (assuming it can drive at all)? Probably not that much less.
Beewi
I mean, it will run on all windows 7, 8, and 10 versions. Any FB marketplace special will work as long as it has a USB drive and a GB of space on it.
ticaf
US Mid-Atlantic
Stock 2015 Golf SW S Manual TDI
OBDEleven folks.... cheap! Works with your smartphone.
Enuff said, no point speculating until we get the codes!!!
dieseldonato
Us
2001 jetta
You can buy a bottom dollar Walmart laptop and it will run vcds like a champ. Heck a refurbished lap top off Amazon will work just fine. Pretty sure this conversation was had a few months ago, with several guys offering solutions for you.
Mass. Wine Guy
I apologize if I’m repeating myself. Sometimes I forget. But it’s probably helpful to others, too.
740GLE
NH
iI is cheap up front and for a one issue use, what's it $70-90?
But the yearly subscription to actually do anything does add up.
even if you know the codes, i don't think you'll be ontop of trying to fix anything, especially with VW warranty willing to replace anything.
I'd say get a tow (or charge up the battery enough to drive) to the dealer of your choice and let them work their magic.
I did have Autofair Nashua just complete Phase 2B on our Passat, they had it for a full week, i can't complain as the cars been trouble free for the week since and i haven't seen any issues.
I'd go back to them and I had to travel 25 min to them.
Mass. Wine Guy
I can use my wife’s Golf this week until she gets home on Monday. But then I’d probably need to rent a car. Dealers aren’t going furnish loaners for this.
740GLE
NH
if its emissions warranty that will require more than XXhrs, i believe they are required to provide you a loaner/rental.
Autofair nashua has an Enterprise rental right next door. They set up the rental when i made my appointment and was a very painless process. Ended up in a 2023 malibu, for 500 miles, damn I hate CVTs, but that 1.5t siiiipppps fuel, +38mpg of regular is mighty nice.
JM Popaleetus
Connecticut
Signature.
I'm only slightly embarrassed to say that the Malibu is my favorite rental car, and I wish they kept making the 2.0T as it was proper quick (0-60 in the mid fives).
I also really appreciate how GM's headlight knob defaults to Auto, and clicks back if you turn your headlights off.
Mass. Wine Guy
So I plugged an OBD module into the car and ran Car Scanner. I made an educated guess for the engine profile. Ran diagnostics. I saw nothing that referred to DPF. And I don’t understand most of what
Also, after jumping the battery and driving for 35 minutes, it didn’t restart again without another boost.
Even though it gives me some dread, I’m taking it to a dealer tomorrow. All seemed to run well until that fan kept coming on. So I’m still hoping it's emissions related and covered.
Beewi
If you plugged in a generic obd scanner, it may not give all your codes. What, specifically, did it ask you for as far as "engine profile"? And what did you tell it? Can you dump the readout here?
And yeah, I would expect that your car needed a boost after driving some more. The underlying cause is still there.
Mass. Wine Guy
I’m sure you’re right. I know that VWs hate low voltage, so I was getting all kinds of warnings on the dash. This is what the scanner found: (and THANK YOU!)
Car Scanner ELM OBD2
Version: 1.108.6/1.108.6/iOS
DTC report
Connection profile: Volkswagen Diesel DPF var.1 EA288 (UDS: MQB, PQ26)Date: 7/28/2024 5:46:03 PM
VIN: 3VWFA7AU7FM508194
OBD-IIOBD-II
DTCs: 3
P068B [0x068B]
Engine control (EC) relay - shut-off delay
Status: Confirmed
P068A [0x068A]
Engine control (EC) relay - shut-off early
Status: Confirmed
P0562 [0x0562]
System voltage - low
System Voltage Low
Status: Confirmed
19. CAN Gateway19. CAN Gateway
DTCs: 3
131654 [0x020246]
U016400: Lost Communication With HVAC Control Module
Timeout_Node_0x46_DiagAdress_08_Klima_MSB
Status bits: 1
Priority: 2
Frequency: 2
Unlearning index: 70
Odometer: 226058 km
Date, time: 2024.07.21 00:00:18
Status: Test failed, Confirmed
01282 [0x000502] Archive (inactive)
U101100: Supply voltage, Voltage too low
supply_voltage_lower_limit_value_fallen_below
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 109
Odometer: 226059 km
Date, time: 2024.07.21 19:03:00
Status: Confirmed
8521278 [0x82063E]
U141100: Battery terminal recognition, Open circuit
Interrupted_Electric_Power_Suppl
Status bits: 1
Priority: 1
Frequency: 2
Odometer: 226058 km
Date, time: 2024.07.21 00:01:59
09. Onboard supply control unit09. Onboard supply control unit
DTCs: 10
131330 [0x020102] Archive (inactive)
Versorgungsspannung - unterer Grenzwert unterschritten supply voltage lower limit exceeded
Status bits: 1
Priority: 6
Frequency: 1
Unlearning index: 108
Odometer: 226038 km
Date, time: 2024.07.21 00:00:00
Status: Confirmed
131586 [0x020202] Archive (inactive)
U140000: Function restriction, due to insufficient voltage
Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten restriction due to undervoltage
Status bits: 1
Priority: 6
Frequency: 4
Unlearning index: 110
Odometer: 226038 km
Date, time: 2024.07.20 22:15:30
Status: Confirmed
539157 [0x083A15]
U112100: Databus missing message
Klima_12 Datenbus fehlende Botschaft
Status bits: 1
Priority: 6
Frequency: 1
Unlearning index: 69
Odometer: 226058 km
Date, time: 2024.07.21 00:00:16
558100 [0x088414] Archive (inactive)
U112300: Databus error value received
Airbag_02 Datenbus empfangener Fehlerwert
Status: Confirmed
939524 [0x0E5604] Archive (inactive)
U10F500: Humidity sensor, No communication
Sensor für Feuchteerkennung-kein Signal/ Kommunikation
Status: Confirmed
204546 [0x031F02] Archive (inactive)
B147A18: Remote key 2, Voltage too low
Funkschlüssel 2-unterer Grenzwert unterschritten
Status: Confirmed
197128 [0x030208] Archive (inactive)
B12DB29: Lock unit for central locking, rear, left, Implausible signal
Schließeinheit für Zentralverriegelung hinter Fahrerseite-unplausibles Signal
Status bits: 1
Priority: 4
Frequency: 1
Odometer: 226038 km
Date, time: 2024.07.20 22:13:58
Status: Confirmed
197384 [0x030308] Archive (inactive)
B12DC29: Lock unit for central locking, rear, right, Implausible signal
Schließeinheit für Zentralverriegelung hinter Beifahrerseite-unplausibles Signal
Status bits: 1
Priority: 4
Frequency: 1
Odometer: 226038 km
Status: Confirmed
934664 [0x0E4308] Archive (inactive)
B136629: Rain/light recognition sensor, Implausible signal
Sensor für Regen- und Lichterkennung-unplausibles Signal
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 226058 km
Date, time: 2024.07.21 00:00:13
Status: Confirmed
329480 [0x050708] Archive (inactive)
B1806F0: Heated seat passenger's side, Safety shutdon due to occupant detection
Sicherheitsabschaltung durch Insassenerkennung (Sitzbelegerkennung)
Status bits: 1
Priority: 6
Frequency: 78
Odometer: 214277 km
Date, time: 2023.12.23 15:21:00
Status: Confirmed
03. ABS control unit
No DTC found.
01. Engine control unit01. Engine control unit
DTCs: 9
05453 [0x00154D]
P308800: Starter relay, Electrical error in circuit
P051200: Starter Request Circuit
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 255
Odometer: 226038 km
Date, time: 2024.07.20 22:15:35
Engine RPM: 0 rpm
Calculated engine load value: 0.00 %
Vehicle speed: 0 mph
Engine coolant temperature: 91.4 ℉
Engine oil temperature: 82.4 ℉
Barometric pressure: 101 kPa
Klemme 30 voltage: 6
Paramteric values: 20 96 28 11FC 18 12 36 03 12 37 62 5A 12 34 00 00 16 41 00 00 25 99 16 42 00 00 00 00
Status: Pending, Test failed since last DTC clear
17158 [0x004306]
U041600: Invalid Data Received From Vehicle Dynamics Control Module
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 226058 km
Engine RPM: 882 rpm
Calculated engine load value: 30.20 %
Engine coolant temperature: 78.8 ℉
Engine oil temperature: 84.2 ℉
Klemme 30 voltage: 13
Paramteric values: 20 96 28 17E0 00 00 17 DD 04 17 DE 00 00 11 87 00 00
20360 [0x004F88]
P332500: Power supply terminal 15, Implausible
P253200: Ignition Switch Run Position Circuit High
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 226094 km
Date, time: 2024.07.28 00:00:02
Engine RPM: 0 rpm
Engine coolant temperature: 192.2 ℉
Engine oil temperature: 138.2 ℉
Klemme 30 voltage: 14
Paramteric values: 20 96 28 14B1 00 00 00 14 B2 00 00 00
Status: Test failed (current drive cycle), Pending, Test failed since last DTC clear
07150 [0x001BEE]
U042800: Invalid Data Received From Steering Angle Sensor Module
P169800: Steering Column Electronics, Read out DTC
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 226058 km
Date, time: 2024.07.21 00:00:15
Engine RPM: 900 rpm
Calculated engine load value: 27.84 %
Paramteric values: 20 96 28 10 60 00 17 E2 00
04708 [0x001264]
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 226058 km
Engine RPM: 876 rpm
Paramteric values: 20 96 28 11A6 00 00 10 60 00 17 E2 00 10 61 00 10 62 00 10 63 00 10 0D 00
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
17262 [0x00436E]
U140A00: Terminal 30, Open circuit
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
04629 [0x001215]
P068A00: ECM/PCM Power Relay De-Energized Performance - Too Early
04631 [0x001217]
P068B00: ECM/PCM Power Relay De-Energized Performance - Too Late
Status: Test failed, Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
25147 [0x00623B] Archive (inactive)
P208B00: Reductant Pump "A" Control Range/Performance
Status: Test failed since last DTC clear, Test not completed during this operation cycle
04. Power steering04. Power steering
DTCs: 3
26885 [0x006905] Archive (inactive)
C10D700: Comfort limitation
Speicherinkonsistenz im Errorhandler
Status: Confirmed
12289 [0x003001] Archive (inactive)
Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung (5,5V für 3ms, KL500)
Status bits: 1
Priority: 6
Frequency: 41
Unlearning index: 40
Odometer: 226058 km
Date, time: 2024.07.21 00:03:31
Paramteric values: 10 17 68 30 00 01 21 72 78 00 00 01 4D 00 D1 00 00 00
Status: Confirmed
10240 [0x002800] Archive (inactive)
Reduzierung der Unterstützung: Versorgungsspannung zu niedrig Allgemeiner Fehler zur Unterspannungsreduzierung
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 226095 km
Date, time: 2024.07.28 17:31:36
Paramteric values: 24 1A 81 28 00 00 21 72 78 00 00 01 92 00 FC 00 00 00
Status: Confirmed
05. Authorization system for access and starting the engine05. Authorization system for access and starting the engine
DTCs: 3
65813 [0x010115] Archive (inactive)
Versorgungsspannung Spannung zu niedrig
Error Kessy Supply voltage too low
Status bits: 1
Priority: 4
Frequency: 6
Odometer: 226038 km
Date, time: 2024.07.20 22:17:10
Status: Confirmed
1052935 [0x101107] Archive (inactive)
B116B11: Driver exterior door handle touch sensor, Short circuit to ground
Sensor für Türaußengriffberührung Fahrerseite Kurzschluss nach Masse
Driver door sensor short to gnd
Status bits: 1
Priority: 4
Frequency: 1
Odometer: 226095 km
Status: Confirmed
1053191 [0x101207] Archive (inactive)
B116C11: Front passenger exterior door handle touch sensor, Short circuit to ground
Sensor für Türaußengriffberührung Beifahrerseite Kurzschluss nach Masse
Co driver door sensor short to gnd
Status bits: 1
Priority: 4
Frequency: 2
Odometer: 226038 km
Date, time: 2024.07.20 22:14:51
Status: Confirmed
15. SRS15. SRS
DTCs: 1
9483264 [0x90B400] Archive (inactive)
B10B400: Function restriction of seat occupied recognition, due to undervoltage
Occupant Detection System limited function supply voltage too low
Bladder Mat: functional restriction because of low voltage
Status bits: 1
Priority: 2
Frequency: 2
Odometer: 226058 km
Date, time: 2024.07.21 00:03:37
Status: Confirmed
16. Steering column16. Steering column
DTCs: 2
114178 [0x01BE02] Archive (inactive)
Status: Confirmed
136194 [0x021402] Archive (inactive)
Versorgungsspannung -unterer Grenzwert unterschrittensupply voltage lower limit exceeded
Status: Confirmed
17. Dashboard
No DTC found.
2B. Steering column lock (UDS)2B. Steering column lock (UDS)
DTCs: 2
13635840 [0xD01100] Archive (inactive)
Under voltage (continued)
Status: Confirmed
13893632 [0xD40000] Archive (inactive)
Under voltage (temporary)
Status: Confirmed
42. Driver door electronic equipment42. Driver door electronic equipment
DTCs: 3
65548 [0x01000C] Archive (inactive)
Versorgungsspannung
Status bits: 1
Priority: 2
Frequency: 5
Odometer: 226038 km
Date, time: 2024.07.20 22:15:33
Status: Confirmed
589829 [0x090005] Archive (inactive)
B131FF5: Rear window regulator, driver side, Voltage supply lower limit not reached
Fensterheber Fahrerseite hinten Versorgungsspannung
Status bits: 1
Priority: 2
Frequency: 11
Odometer: 226038 km
Date, time: 2024.07.20 22:13:52
Status: Confirmed
589839 [0x09000F] Archive (inactive)
B132102: Driver side rear window regulator motor, Signal error
Motor für Fensterheber Fahrerseite hinten
Status bits: 1
Priority: 2
Frequency: 3
Odometer: 226038 km
Date, time: 2024.07.20 22:15:46
Status: Confirmed
44. Power steering44. Power steering
DTCs: 3
Status: Confirmed
Status bits: 1
Priority: 6
Frequency: 41
Odometer: 226058 km
Status: Confirmed
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 226095 km
Status: Confirmed
52. Front passenger door electronics52. Front passenger door electronics
DTCs: 3
Versorgungsspannung
Status bits: 1
Priority: 2
Frequency: 5
Odometer: 226038 km
Status: Confirmed
589845 [0x090015] Archive (inactive)
B1320F5: Rear window regulator, front passenger side, Voltage supply lower limit not reached
Fensterheber Beifahrerseite hinten Versorgungsspannung
Status bits: 1
Priority: 2
Frequency: 12
Odometer: 226038 km
Status: Confirmed
589855 [0x09001F] Archive (inactive)
B132202: Front passenger side rear window regulator motor, Signal error
Motor für Fensterheber Beifahrerseite hinten
Status: Confirmed
55. Headlights corrector
No DTC found.
5F. Electronic Information System 15F. Electronic Information System 1
DTCs: 5
01537 [0x000601] Archive (inactive)
Supply voltage - lower limit value not reached
Status bits: 1
Priority: 3
Frequency: 1
Odometer: 226058 km
Date, time: 2024.07.21 00:03:20
Paramteric values: 02 86 8B
Status: Confirmed
01539 [0x000603] Archive (inactive)
Funktionseinschränkung durch Unterspannung -unterer Grenzwert unterschritten
Function restriction due to insufficient voltage - lower limit value not reached
Status bits: 1
Priority: 6
Frequency: 14
Odometer: 226038 km
Date, time: 2024.07.20 20:50:06
Paramteric values: 02 86 46
Status: Confirmed
00020 [0x000014]
B11CF53: Tuner for satellite radio, Deactivated
SDARS tuner not enabled/activated
Status bits: 1
Priority: 4
Frequency: 1
Unlearning index: 129
Odometer: 204425 km
Date, time: 2023.05.25 13:19:04
Paramteric values: 02 86 7B 24 46 FF 00 00 00 FF FF 00
06669 [0x001A0D] Archive (inactive)
U10CC00: Optical data bus for digital sound system, Sporadic disruption
Optical data bus, sporadic open circuit in sound
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 226058 km
Date, time: 2024.07.21 00:00:28
Paramteric values: 02 86 8D 18 67 58 1F 70
Status: Confirmed
07169 [0x001C01]
U111100: Function limitation due to missing message
Klima (0x01) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful
U111000: Function restriction due to communication interruption
A/C system (0x01) - function restriction due to communication error - BapErr_retry not successful
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 226058 km
Date, time: 2024.07.21 00:00:19
Paramteric values: 02 86 92 18 44 02
75. Emergency Call and Communication Module75. Emergency Call and Communication Module
DTCs: 4
00036 [0x000024] Archive (inactive)
External GPS, No communication
CAN TO GPS data
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 226058 km
Date, time: 2024.07.21 00:00:22
Status: Confirmed
Supply voltagetoo low
Status bits: 1
Priority: 3
Frequency: 1
Odometer: 226038 km
Date, time: 2024.07.20 22:14:59
Status: Confirmed
Functional restrictiondue to insufficient voltage
Status: Confirmed
07170 [0x001C02] Archive (inactive)
Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful
Status bits: 1
Priority: 6
Frequency: 1
Unlearning index: 76
Odometer: 223673 km
Date, time: 2024.06.28 14:29:20
Status: Confirmed
Beewi
You are correct that low voltage is making the car freakout and drop dozens of errors on you. If you have a jump pack that can supply power, could you slap that on the car and run a scan again? That way the only issues will be ones NOT related to having a dead battery.
