Twin Cities MN/Western WI GTG: June 7, 2014
KCCats
North Central IL
03 Jeta Wagon
Im new here and would love to make the trip! I just got my third VW! A 03 Jetta TDI Wagon! Prier I have a 97 Golf and a 95 Golf with a trans plat ECO!
Is there going to be a gathering perhaps a bit closer to North Central Il?
Couleetdi
West Wisconsin
2015 Passat SE TDI
Gtg mn wi
I've got it on my calendar, plan on attending. Appreciate anyone with Vagcom to see what is going on with my ABS.
couleetdi
1st_TDI:)
central MN
2000 Jetta Forest Green
I know I was talking about this and I will probably shoot for early/middle May (so we can have the doors open, etc. I will edit this thread as time goes on.
Here are the details I have so far.
DATE: June 7th!
Time starts 9:00 AM
Midwest Motorworks
680 County Rd U
Hudson, WI 54016
We will be having a parts sale etc. If you want to buy parts let me know what you want me to have on hand.
JFettig and I will be able to do chip tuning on the spot, we are both Malone Tuning dealers. JFettig is the only one with equipment to do 99.5 and older TDI's (we will double check with Mark Malone on a set date to make sure he is available). I would like to have a list of people and cars (year, model, mods) so we can plan accordingly.
Food and stuffs we will have to plan, gas grill is available for use.
We should have a vag tacho cable buy then, so if anyone needs keys immobilized and adapted that will be the time, it won't be free but it will be a LOT less than the dealer :)
Not sure if my boss will allow any wrenching, but we'll see.
Also if I can get a list of who is planning on showing up.
Let's do this!:):D
Wish I could attend. Already have booked a trip to SD that weekend. I could really use my spare key getting programmed for the car. Wish there was a way just to get the PIN for my car and I could deal with it later.
Hope to meet up some time soon.
tom007
edina, mn
99 vw beetle tdi
hi jon
do you still have a time slot foe me to get a stage 1.5 malone tune? Had the injection timing corrected, boost issues fixed and new stock turbo installed so i finally think i'm good to go now.
tom007
edina, mn
99 vw beetle tdi
Also if you have a drivers side door handle bezel that woud be interseting
Thanks much
klettn
Spring Valley WI
03 Jetta Wagon, 03 Jetta Wagon (with stuff added), 83 Mercedes 300SD, 06 Duramax
DATE: June 7th!
Time starts 9:00 AM
Midwest Motorworks
680 County Rd U
Hudson, WI 54016
Let's do this!:):D
Will try to make it as well. Would be interested in Stage 1 for the wifes car so I have an excuse to put a new clutch in if it goes. Not to mention the check engine light that has been since the egr delete performed at the host shop, but that is my own fault for not wanting to get a tune just for the egr delete.
slug1121
Cushing, WI
2004 BEW Jetta 5spd (x2), 2005 GLI BMP
As of right now I'm scheduled to work, but if I can get that changed I'll be there!
KCCats
North Central IL
03 Jeta Wagon
Im debating on coming or going to StLouis?
I need to have mine tuned and the egr delete light off! Plus the air bag light is on?
KCCats
North Central IL
03 Jeta Wagon
Can the air bag module be reset at this gathering? Or should I send mine in and have it done then go to the TDI Feast in St Louis?
teufelhunden
Otsego, MN
14 Jetta TDI
I'm ready to get the Malone software update on my 2014, but unfortunately my nephew's grad party is on the 7th and I'd catch hell if I didn't attend. I'm at about 14k on the car now and when I talked to Malone, he said even if dealer service is needed under warranty the tune is hardly detectable. Anyone have experience with this? Also, I'm debating stg 1.5 vs 2.0. I read that the EGTs can get high without the DPF delete using the 2.0, thoughts on this? I plan on a DPF delete after the warranty is over as well as a 3" straight stainless exh like I had on my MK4, but again, that's a year or so out. Jon, you're likely closer if I came to you for the tune.. PM me and let me know what your schedule looks like the weekends following the GTG. Thks, Matt
Couleetdi
West Wisconsin
2015 Passat SE TDI
Vagcom Cable
I am still planning on attending, just want to verify whomever was bringing their Vagcom cable, are you bringing your laptop along too. I had Vagcom software loaded on my laptop; seems laptop is not working too well. I dropped it last night, so using wifes laptop for now. I'll check back by Friday to make sure. Appreciate the help guys/gals on this.
Thanks coulee
KCCats
North Central IL
03 Jeta Wagon
Well I can't make it this weekend! And I just read that StLouis is canceled?
Now what do I do?
Is there anyone in the greater Chicagoland area that can help me?
I want the Malone tune as well as a few other things?
Is there a list somewhere on what all can be done with the lap top! Excuse me that a tuner can do with a lap top!
JFettig
Blaine, MN
B5 Passat, 2010 Jetta
KCCats, we can tune your ecu, either Merker or I, check out malonetuning.com for more info on that. There are other small things that can be done, there should be others who know how to run vcds that can take care of other small VCDS mods for you as well :)
Couleetdi - you can install vcds on any laptop to run your cable, the cable is the dongle so that works.
Matt, we can discuss your tune anytime you want, feel free to PM me. EGT fears on these cars are just that, fears. You have 4 EGT probes in your exhaust, one pre-turbo which monitors your EGTs, the ECU will prevent your EGTs from getting too high in any condition. Yes they get hot, exhaust gas is hot :D They get hotter than your old ALH because these TDI's run much richer due to their advanced fuel system, your old TDI would start to smoke around 17-19:1 AFR, these don't make soot until sometimes below 15:1 AFR. They do make more heat the richer they get!
I'll be available anytime you wanted a tune upgrade, we can chat about that.
white09, I'll be there until 3 or 4pm at the absolute latest. I think that is about what we're planning.
