Turning on rain sensor
Bearsvw
Orleans ont
2013 passat highline loaded
I would like to activate rain sensor for closing and wipers. Also like the close feature by remote. Does anyone ln my area do this or can it be done .
Rico567
Central IL
I can answer the latter of your two questions (I'm assuming that our 2013 Passat TDI Sel Premium is the same car as your Highline— in fact, the vehicle information sticker in the spare tire compartment on our car didn't say "SEL," it said "Highline," even though the vehicle is otherwise badged and marked for US delivery).
It can be changed, despite the fact that some may tell you "no." We took our car in to the dealer for the complimentary 1,000 mile check, and asked if the wipers could be activated. Their reply? "Only in South Korea." At that time, I knew that further dialogue would be useless, so I waited until I got the deal I wanted on VCDS and activated it myself. I haven't tried the auto-close, but the wiper sensor works fine.
atc98002
Auburn WA
2014 Passat TDI SEL Premium (sold back), 2009 Jetta (sold back), 80 Rabbit diesel (long gone)
Don't forget that VW removed the rain sensor some time between the 2013 and 2014 models. Mine doesn't have it, even though it still has the same housing on the windshield. Make sure it's actually there! :)
tadawson
Lewisville, TX
2013 Passat TDI SEL, 2015 Passat TDI SEL
The procedure is in the sticky at the top of this section . . . So, if you can find someone with VCDS, it's not too bad to do. We have a 2013 SEL, and I enabled (and verified) the rain sensor, as well as auto close, and while in there, put the ability to turn off the DRL's in the menus . . . all have worked fine for years . . . .
- Tim
tdiatlast
Fort Worth, Texas
tadawson: I don't know how many rain sensors worked/didn't work, but the reason VWoA discontinued them during the 2013 run, according to some, was because they didn't function consistently. Caveat emptor. In my 2012, they were erratic.
sleek98
Kansas City
2013 Passat TDI
our 2013 works, it sometimes random goes off when its dry out but not enough to make me want to turn it back off. I like it a lot.
tadawson
Lewisville, TX
Yeah, I get the random swipe at times too . . . seems like it's when there is a flutter of light/dark and similar, seems to fake it out . . . Not a big deal, and if you turn the wipers off when no rain, becomes irrelevant anyhoo . . .
tadawson
Lewisville, TX
Unless you are in other countries . . . they they thought they were gold. I greatly suspect this was a marketing decision, to not give an "Audi-esqe" feature more than anything related to function, but likely we will never know for certain . . .
Booth44
SW Ontario
2013 Passat SEL
I activated my rain sensor with VCDS and love it. As others have noted, the only real problem with it is the occasional random wiper swipe on a dry, sunny day. I find the sytem works very well for controlling the wipers in all types of rain. I rarely manually override it.
jrm
Oregon
2013 Passat SE with nav (totaled)
just don't rain x over the sensors, luckily I haven't done that but others report crazy wiper behavior
VernK
Kelowna
2012 Passat 2.5L Gas
I could see RainX causing a problem, as it makes the water bead up. The beads would act as little lenses, and that probably confuses the sensor which works optically.
As I recall, the rain sensor was disabled because the software was buggy, not the sensor itself misbehaving. But as mentioned we'll never know for sure.
Yours
Vern
IXLR8
Cushing, ME
12 Passat Platinum Gray, 02 Golf Black, 01 Jetta Black
I activated the rain sensor on my '12 Passat, I like it. It has gotten confused occasionally and won't work at all and I need to turn off the wipers, shut off the car, then restart the car and this seems to clear it's head for a while. This has happened 3 or 4 times in the last 4 years. I get an occasional wipe when dry, but my '16 BMW X5 does the same thing as well.
dzampi
Vancouver, Canada
2013 Passat TDI Highline
Same thing here...sometimes it works perfect but sometimes it does not. Shutting the car off and restarting it will sometimes clear the problem and then it works flawlessly...
Rico567
Central IL
We get the occasional dry wipe, but nothing that needs fixing. I think the disconcerting thing about the operation of the system (for a little while, anyway, we got used to it) is that the operation isn't continuous, as it was with an earlier car we had. It can activate the three modes that existed (intermittent, low, high) before it was activated, and that's it. The other car, a leased '04 SAAB, had a rain-sensitive system that apparently operated continuously, that is, it had available any number of speeds, which it adjusted to the current amount of water hitting the sensor. The VW system is different, but it works.
tdiatlast
Fort Worth, Texas
I'm OCD about dry swiping of the wipers, which over time, contributes to premature wear of wipers and glass. I disabled the sensor on our (traded) 2012. I never move my wipers unless the windshield is wet.
Did I say I was OCD? I can't remember, my ADHD jumps up every once in a while.
tadawson
Lewisville, TX
It's not like the once a month it happens is much of an issue, and if you turn the wipers off when it's not raining, it won't do it all all. Maybe it's me, but I don't use this as the "duh" mode and leave it there all the time, but simply as a better choice than intermittent in light spit, and still select slow or fast when the rain required, and off when it's dry . . . . Never an issue . . . Perhaps it's *MY* OCD that won't let me have the control anywhere but off when it's not raining . . . just need to learn how to apply our quirks for the greatest benefit!
And again, I note, that the only place that got the BS about "the software being flaky" was the US . . . it deployed in other countries, so I tend to call BS on that . . . I *still* maintain it was to maintain the gap between VW and Audi via "stupid feature wars" (TM) . . .
La Conner, WA
Pro tip: Even with the rain sensor enabled, the OFF position on the wiper stalk still works. ;) :D
tdiatlast
Fort Worth, Texas
"Pro" tip: Yup...off works, of course. Kinda defeats the purpose of a rain sensor, doesn't it?
Please consider that there are OTHERS driving our cars, folk who aren't as OCD as the average TDI owner...wives, sons, daughters, who aren't always capable of noticing it's raining, hence the value of a "rain sensor" that will close all the windows/sunroof, and turn on the wipers. HAHA!
La Conner, WA
If your fellow drivers aren't capable of responding appropriately when it rains, perhaps they should go back to driver's ed, eh, Ed? HAHA! Sorry, that was terrible. :( :D
tdiatlast
Fort Worth, Texas
Thanks, VeeDubTDI. I've forwarded your advice to my fellow drivers, along with your phone numbers, email addresses, and physical address. They now know where you are.
They will be contacting you directly.:D:D
La Conner, WA
tadawson
Lewisville, TX
Not in the slightest! i regard the sensor more as "smart interval" than "no-thought" mode, so for me, off is completely natural. The sensor just keeps me from having to dick around with setting the interval as the rain rate varies, nothing more . . .
tdiatlast
Fort Worth, Texas
^^^got it. It's not a "it's starting to rain" sensor, but a more sophisticated active wiper system. You're right!
