Lance Allison
Requiesce In Pace October 20th, 2019
There are some related posts on this problem, but they are unique to A4 cars, namely A4 turn signal/hazard switch relays, so I'm thinking I may have a different problem since I have an A3 Jetta.
I needed a new right rear brake light bulb, so I bought 2 from the dealer and replaced both sides.
Now here comes the problem...right now a few things are happening at different times.
1. Brake lights and turns work as designed (happens about 75% of the time) OR...
2. Turn signals do not flash at all, both directional indicators on the dash come on dimly when the brake is pressed, and the brake lights do not work. Sometimes this varies and the turn signals and brake lights come on very dimly. (About 15% of the time) OR...
3. Brake lights work normally, but the turn signals flash very quickly. (remaining 10% of the time).
I cleaned all 4 sockets and tried new bulbs in the brake lights and in the front turns. Also, if situation 2 or 3 happens, if I remove and reinstall the rear brake light bulbs, the problem appears to be resolved for awhile...sometimes days.
Any ideas?
[ February 14, 2003, 22:32: Message edited by: Lance Allison ]
Any ideas?
