Turbo whine/whistling
sheepman
Denton, Texas
2006 Jetta TDI Special Edition 5 speed
Ours is new with 700 miles on it and it makes the same noise. I figured it was the fuel pump. I could be wrong.
tdiatlast
Fort Worth, Texas
I don't hear anything, except a hi-pitched electronic "whine"...doesn't sound turbo/mechanical related, although you didn't rev the engine...
I'm at 23k miles. At 9k miles, my turbo started whistling/whining on the return trip to DC from Brandenton, FL. We were stuck in I95 traffic, and while creeping forward, on/off throttle, we all thought we heard emergency equipment approaching...a very faint whine/whistle unrelated to our car's momentum. I ultimately isolated it as coming from the turbo.
14k miles later, no change...not louder/softer...still there. No change whatsoever in engine temp, operation, MPG (although it DOES appear louder right after I read about "turbo failures":D:D).
So...what does all this mean? I have no clue. My turbo whines/whistles the way a "normal" turbo should!!!
in2dwww
USA
2013 Passat TDI SEL, 2010 Jetta TDI Sedan 6MT - sold
I played the video the first time and heard a slight whine. Then I replayed the clip and the sound went away!
That's exactly what the VW dealer will tell you as well.
FormerGasser
Colorado
2013 Passat TDI SE 6M
I was curious about this as well. I know what the typical whine/whistle sounds like but mine also at times will make a "blow-off" noise. Like evo's and such with noisy blow-off valves. Definitely not as loud but I can still hear it. Never heard it on my Jetta and just recently started to hear it on my Passat with 7k miles. Normal?
Rockwell
Manchester, NH
2003 Jetta TDI (R.I.P.), 1.6TD Toyota pickup, 2011 BMW 335d, 1996 Passat TDI
I have a video clip of what mine sounded like 30 minutes before the turbo blew, I dont know how to post but can Email.
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
All pictures videos have to be posted on a host server somewhere else first then linked back to here. Photobucket, youtube and such and post the link to it in your post here.
Rockwell
Manchester, NH
Just curious: What provoked you to be taking a sound clip at that moment? Was it the sound?
FYI: This sound is NOT the same whistle/whine sound that I have in my 23k miles Passat.
for a few days it was a nice whistle like my ALH had. I had the radio off so I could monitor it. Over the course of about 5 minutes in went from a whistle to that sound, I recorded it to post here to ask about it. It kept getting worse until it failed 30 minutes later and fell silent. I called dealer and they said to drop off in the moring. I got home and shut it down. I restarted it and the impeller sounded like it was bouncing around loose, I shut it back down and had it towed.
But to answer your question, I knew it didnt sound right.
At the first stage of failure it sounded like a normal turbo whistle, maybe yours is staying at that stage? I would at least have the dealer check it out and let them tell you its ok, that way if you do have a problem down the road, at least its documented that you had a concern.
La Conner, WA
Oh jeez - don't get tdiatlast any more worked up about the sounds his car makes. ;)
JdC Machine
Cypress, CA
'13 Passat TDI SEL
That "whine" sounds more like the frequency given off by one of the stepper motors beneath the car.
