Rub, will it bolt up to AGR manifold? What's the engine code for 16v 170hp PD?Rub87 said:u
option is borg warner gt1749VC equivalent found on 16v 170hp PD in audi A4, bolts up perfectly to afn manifold..
Rub87 said:or gt18v from opel hybridzed with 52mm compressor is a acutally a vnt20 but with nicer vanes =) just needs an adapterplete because the 3 bolt flange is clocked 30° wrong
No...12MPGHWY said:I see, is that the same for the KKK turbo, that is three bolt flange just clocked differently?
So I would need either adapter plate, which is fine and easy to make or an AFN exhaust manifold?
Is that correct?
So how does someone on the west side of the pond get ahold of an AFN manifold found on the east side of the pond?Rub87 said:No...
KKK turbo is 100% pnp on AFN manifold
and gt18v need adapterplate with afn manifold..
I don't like the AHU/1Z manifold so much![]()
I have this turbo on my Audi A4 AHU...Rub87 said:03G145702H
Engine code BRD
Pics aren't mine.. but I'll post the link..
http://picasaweb.google.com/goskamisiak/BRD#
Rub87 said:problem is that the shipping will cost more as the price of the manifold
btw it's also found on ASV engine in ibiza 6k2, or A4/passat/A6 8V PD and vp37 engines
looks bolt-on indeed...12MPGHWY said:
Yes seems it'll fit.. if the passat is 8v it will fit just fine..12MPGHWY said:http://i50.photobucket.com/albums/f305/joericambi/a6-170-bhp-turbocharger.jpg?t=1220973691So it my be the same manifold or compatible as found on the US model 2.0 PD Passat?
Can anyone confirm this?
Here is the KKK Audi turbo, and the US model PD turbo showing the flange, sure looks like they would bolt to the same manifold.
