onlyn8v
- Joined
- Nov 14, 2005
- Location
- Long Island NY
Hey Jeff- sent Im...
my stock gt15 made 116.9hp and 240tq and thats before it hit overboost.and yes it smokes alittle.hope to see higher numbers w/ my new 3" down pipe.may come back w/ a newer intake too.mojogoes said:1/ No the stock turbo would not have produced this kind of increased power result , as it would have been out of its efficiency map and created more hot air......not cold/cool.
My stock gt15 made a 146hp with B.216's and fmic with a the oe down-pipe @ 18psi and probably the smoke as you report...........i guess i should have possibly changed that and the inlet-manifold to see even lower smoke output.87turboquattro said:my stock gt15 made 116.9hp and 240tq and thats before it hit overboost.and yes it smokes alittle.hope to see higher numbers w/ my new 3" down pipe.may come back w/ a newer intake too.
remember,this has rc3 and 640 ohm every mod.
mine were done on at the wheels on a conservitive dyno no less.not too bad for 233k miles.mojogoes said:I would think @ the crank
Do you know what the max boost pressure that the super17 can give sustained and what steady state pressure do you see on your gauge.curtg said:i have the super 17,but like what scott did i also did,switched turbos at same time as downpipe no cat and 3in exhaust.so i felt power right away.
i see alot has happen in few months. i live were i work so i do not drive as much as i like,but i do now have 3500 miles on my turbo.is anyone else running super17?any feed back positive or negative.i am gonna try and get in touch with jeff for rocketchip tune and dyno in spring
You and Aaron both felt the gains since you swapped in this turbo AND upgraded the exhaust/cat AT THE SAME TIME. This is NOT the case with ME.curtg said:i have the super 17,but like what scott did i also did,switched turbos at same time as downpipe no cat and 3in exhaust.so i felt power right away.
That was exactly my reasoning. And there's a number of them out there with good success/reliability thus far. I would say you can buy one of these with confidence.Stealth TDI said:BTW, please don't take my posts to understand that I find the K03/K04 to be a worthwhile, $900 performance upgrade. $900 is a lot to spend for nine horsepower. But it's money well-spent if you're replacing a K03 that NEEDS replacing since you would need to spend $650 anyway.![]()
That's my thinking as well and will probably postpone the purchase until the stock turbo gives out (if ever!)$900 is a lot to spend for nine horsepower.
mojogoes said:Do you know what the max boost pressure that the super17 can give sustained and what steady state pressure do you see on your gauge.
I'm willing to pay $20Stealth TDI said:I offered to dyno the two turbos in another discussion if I could get about $150 in donations (the cost of the two dyno sessions)... My offer still stands if the funding comes through. But I'm done spending my own money to prove this thing's no improvement over the less-expensive K03/K04!![]()
I would suggest that you look into upgrading the injection pump at the same time, to an 11mm ALH automatic pumpquietmission said:Soon, i will be able to report back on the vnt swap and power in the MK3 platform. I have a mild ported rebuild head at Chill's and a vnt17vb on the way. I plan to use PP502 or 764 with an RC tune (undecided). I want to see if i can break the 150whp barrier in the mk3.
