ToeBall
While at the Texas TDI Club GTG yesterday, TDIinTexas lent me a hand a couple of times and we managed to pull my "turbo muffler". For those that don't know about this, VW decided to cut down on noise by putting a muffler on the compression housing outlet pipe of the turbo on the 2.0 CR TDI's. The result is that the turbo is exhaling through a 1 1/8" straw on its way to the engine.
IMG_0278 by Toe_Ball, on Flickr
This is the dampener housing after it's been gutted. At the top of the picture by the Dremel you can see one of the baffles (or what's left of it). The diameter of the whole dampener was the same as the ID of the baffle chunk. Definite flow improvement.
Well anyway, we managed to pull this out, and then I opened it up using a Dremel, a hole saw and a lot of time, I hollowed it out, and smoothed it as best I could, not perfect, but good enough for the time being. TDIinTexas has drawn up the flange and thinks he can make an aluminum replacement, which will be nice as it's bound to flow better than my Dremeled out phenolic plastic one.
On my 5 hour drive home, I noticed a few things of interest. On the freeway, cruising, the engine sounds about the same. When accelerating, above 2500 RPMS under high load, the engine makes a more pronounced growling sound. Above 3000 RPMS under medium load or higher, a distinct hiss is audible, no whistle. There is definitely less turbo lag, quite a bit less. I seem to be getting better millage.
This last one, I'll have to monitor to be sure, it's only based on instant mileage. My average driving up to the GTG was 37.5 MPG, my average on the return was 39.7 MPG. Driving conditions were significantly different. I hit traffic on my way back, I tanked up so fuel could be better quality, I was technically driving down hill on the way back as well. I also took a different route, but I don't think that was beneficial. Anyway, too many variables for those numbers to be absolute, but I do think that the engine breathing easier did improve mileage.
