TURBO: Please report NMS turbo failures here. [not a discussion thread!]
psd1
OR
2006 Jetta 2013 Passat SE 6Man
Data Compilation to date: 3/9/14
2012 Passats = 21
2013 Passats = 47
2014 Passats = 0
Highest mileage turbo failure: 100000
Lowest mileage turbo failure: 660
Average miles for last 6 failures: 24,020
Total miles traveled 1,230,438/66 cars =Avg miles at failure 18,643 miles.
High temperature at failure: 86*
Low temp at failure: -10*
Avg temp for last 6 failures: 12.5*
Average temp at failure: 25.3* 1341*/53 = 25.3*
Transmissions in cars with turbo failure:
DSG: 25
6M: 32
Unknown: 13
From April-September 2013 there were five reported turbo failures in this thread. Warm weather.
From November 2013-March 9th 2014 there have been thirty five (35) reported turbo failures.
From thread inception to today members report a failure every 5.77 days. 404 days/70 failures.
Once again we have another cold week and another 6 reported turbo failures.
Hauger38
Belleville
2012 Passat
Kilometers on car at failure: 40,000 (approx 26,000 miles)
Build date: Unknown (2012 model)
Corrective actions from dealership:Replacing Turbo.
Outside air temps at failure: + 2 C
Failure warning signs, if any: Glow plug light flashing no power
Warning lights on dash/MFI: Glow plug light flashing
Problems since replacement: Still being worked on.
Repair time:Unknown right now.
Any dealer divulged info on other incidents involving other failures: no
Did the dealership perform all maintenance and on schedule: Yes
If not dealership, what oil was used/miles on oil: I hope they used the right oil they never give me any detailed work orders
Are you the original owner of the car: Yes
Did you baby your car or not: Not really but didn't floor it either
Do you interrupt DPF regenerators: Could have interrupted them
How long is your daily commute: 25 km (about 15 miles) - Frequent 600km highway trips
Transmission:DSG
Bad Eric
Windermere FL
Passat 2012
2012 VW Passat TDI 61,000 miles turbo failure. original owner driven medium hard. 75% highway 25% city. Was one of the first 2012 TDI's off the line built in Tennessee. Dealership wants $3000 to replace the manifold (part# 03l-253-056-QX)and oil pressure switch since its also leaking (part# 036-919-081-d). I live in Orlando FL and never had a problem. There has been some cold weather here lately some days down into the 40's (I know its not as bad as the rest of the country)
Turbo symbol, check engine light and diesel particle filter light have all come on at various times.
Miles on car at failure: 61000
Build date: purchased new oct 2011
Corrective actions from dealership: replace turbo manifold
Outside air temps at failure: 70F
Failure warning signs, if any: none
Warning lights on dash/MFI: turbo sensor (looks like a set of boobs) check engine and diesel particle filter
Problems since replacement:did not replace yet
Repair time: 10 hours labor at the dealership
Any dealer divulged info on other incidents involving other failures:none
Did the dealership perform all maintenance and on schedule: no
If not dealership, what oil was used/miles on oil: Castrol diesel oil purchased at the dealership. dealership did first 3 I did last 3.
Are you the original owner of the car: yes
Did you baby your car or not: average not too hard but not too soft
Do you interrupt DPF regenerations: I don't know what this is
How long is your daily commute: traveled all over Florida
Transmission (DSG/auto or manual): auto
Failed turbo part number (if known):
Replacement turbo part number (if known):03l-253-056-QX
newguy
Minnneapolis MN
2013 Passat TDI SE 6M White
Blown turbo
My car is still at the dealer and I am going to trade it in on a 2014MY identical car. The trade in value they are offering is outstanding and the new vehicle price is very good too... so I won't own this car any longer.
  • Miles on car at failure: 15,500 miles
  • Build date: I think it was 8/12
  • Corrective actions from dealership: in the shop now for a turbo, oil lines and intercooler as the dealer said it had blown metal chunks into the intake stream
  • Outside air temps at failure: about 25F
  • Failure warning signs, if any: loud whine from turbo - but it didn't acutally stop working, just got really noisy so I took it in
  • Warning lights on dash/MFI: none
  • Problems since replacement: I don't have the car back yet.
  • Repair time: it's already been in 5 days
  • Any dealer divulged info on other incidents involving other failures:
  • Did the dealership perform all maintenance and on schedule: yes
  • If not dealership, what oil was used/miles on oil:
  • Are you the original owner of the car: yes
  • Did you baby your car or not: no - I ride it hard
  • Do you interrupt DPF regenerations: yes
  • How long is your daily commute: 20-25 miles usually round trip
  • Transmission (DSG/auto or manual): manual
  • Failed turbo part number (if known): ?
  • Replacement turbo part number (if known): ?
readuetdi
Seattle
Passat 2013 SEL, previously Jetta TDIs (3)
two turbo failures
First (original)
Miles on car at failure: 9500
Build date: 07/2012
Corrective actions from dealership: replaced turbo. shaft loose.
Outside air temps at failure: varied 30-40F mostly, no abrupt failure
Failure warning signs, if any: started definite whine so took in to dealer
Problems since replacement: see below -- second turbo bad
Repair time: 9 days
Any dealer divulged info on other incidents involving other failures: none
Do you interrupt DPF regenerations: possible - not sure I always recognize them
How long is your daily commute: about 20 miles total
Transmission (DSG/auto or manual): DSG
Failed turbo part number (if known): 0005
Replacement turbo part number (if known): 0005
Second turbo failure
Miles on car at failure: 9550 (less than 100 miles after earlier replacement)
Build date: 07/2012
Corrective actions from dealership: "adjusted" turbo, returned car, then failed again within 2 miles. stated problem for second turbo was boost system sticking.
Outside air temps at failure: 40F
Failure warning signs, if any: abrupt limp mode and dash lights, same symptoms after "adjustment"
Warning lights on dash/MFI: yellow coil light flashing
Problems since replacement: seems ok after 3rd time in shop, second turbo replacement
Repair time: 7 days
Do you interrupt DPF regenerations: generally don't pay much attention
How long is your daily commute: 20 mi total
Transmission (DSG/auto or manual):DSG
Failed turbo part number (if known): 0005 (second one)
Replacement turbo part number (if known): 0005 (now #3)
rustycat
seattle
2015 passat sel
Which dealer are you going to? And, how happy are you with them?
Just curious, as I'm a local that may need a turbo replaced at some point.
Rgds. RC
psd1
OR
I didnt get a chance to update this thread yesterday, but rec'd a PM from an individual that suffered two failures. So that will mean another 7 failures reported last week. I may get this done at lunch today.
psd1
OR
Update 3/17/2014
Data Compilation to date: 3/17/14
2012 Passats = 23
2013 Passats = 52
2014 Passats = 0
Average miles for last 7 failures: 23,078
Total miles traveled 1,391,988/73 cars =Avg miles at failure 19,068 miles.
Avg temp for last 5 failures: 34.4*
Average temp at failure: 1,513*/58 = 26.08*
DSG: 29
6M: 33
Unknown: 15
From November 2013-March 17 2014 there have been forty two (42) reported turbo failures.
From thread inception to today members report a failure every 5.35 days. 412 days/77 failures.
I have added info from kat1234 who PM'd me info last night.
psd1
OR
FROM MEMBER kat1234 PM'd.
For some reason, I cant post on this page but I looked up this thread because I have had TWO Turbo Blowouts on my 2013 Volkswagen Passat.
The first one occurred in January (1 month after receiving the brand new car) and the second one just happened yesterday while driving on the highway.
#1 Under 10k Miles
#2 Under 30k Miles.
This is very concerning to me because when this occurs, my entire engine and battery turns off almost immediately after the glow plug light goes on. Therefore, there is no time to react and get to a safe location.
I am not receiving any answers, any apology for safety risks, or any guarantee that this wont happen again.
The first incident caused my car to be in the shop for 6 weeks and I am being told that the part is on backorder and probably will not be available for 2 weeks.
I am seeing the first incident occur for many and it concerns me that they probably dont know that this could or probably will happen again.
I cant think of a greater safety risk than an engine and battery shutting down while driving on the highway.
Thought this information might be helpful.
Thanks,
readuetdi
Seattle
Auburn VW -- this is 4th TDI from them, have been very satisfied up to this point. Frustrated, working with VW now although dealer has been very supportive -- I think we should have another vehicle. Will report back.
strokendiesel002
Southeast Wisconsin
2013 Passat TDI SEL Premium
Strokendiesel002; 2013; 37,082; DSG; 30*f; WI; build date unknown, but I bought in September of '12 it was already at the dealership.
Occurred 3-18-14 approx. 7 am Used auto start while finishing getting ready for work, got in, 1 mile of 35mph 1 mile of 45 mph stop light. puke. $103 tow to dealership. Gurnee VW in Illinois. Received a call approx. 4 pm 3-18-14 informing me they thought it was the turbo, but had more diagnosing to do. 3-19-14 received a call in the am confirming it was the turbo. should be ready tomorrow. will update
DubbaYou
NH
2013 TDI SEL
2013 Passat TDI SEL Turbo Fail at 5500miles
My wife's 2013 Passat TDI had a turbo fail in February at 5500miles.
Mechanic quote on repair paperwork: "Found code P0299 for turbo power under boost. Removed upper engine cover and intake hose. Checked turbo shaft and found play near intake side of turbo. Removed lower engine shield and lower hose to intercooler. Checked for metal. Contacted VW and created VTA. Instructed by VW to replace turbo. Did."
Ran beautiful until the failure.
Miles on car at failure: 5500
Build date: AUG 2012 per door pillar sticker (2013 per VIN decode)
Outside air temps at failure: 20F
Warning lights on dash/MFI: Check Engine Light ON and Glow Plug Light Flashing
Problems since replacement: none
Repair time: 10 days, waiting for part to ship from Germany
Did the dealership perform all maintenance and on schedule: none required yet. Car odo is just 5500 miles
If not dealership, what oil was used/miles on oil: Factory oil
Did you baby your car or not: Wife = hard accel, hard brake
Do you interrupt DPF regenerations: ?likely
How long is your daily commute: wife running errands
Transmission (DSG/auto or manual): D?SG
Glacier Blue
Lehigh Valley, PA
2013 Passat SE TDI DSG
This is a Glacier Blue 2013 Passat SE TDI
Miles on car at failure: 28000
Build date:----
Corrective actions from dealership: replace turbo - with a larger turbo, pump,pies, etc...
Outside air temps at failure: 7degF
Warning lights on dash/MFI: coil flashing the check engine
Repair time: almost 2 weeks
Any dealer divulged info on other incidents involving other failures: not at this dealership but the VW phone tech my mechanic called was aware of another
If not dealership, what oil was used/miles on oil:---
Did you baby your car or not: absolutely - never ran over 3000rpm - garage kept
Do you interrupt DPF regenerations: no - I have to find out how to identify when its happening
How long is your daily commute: 75mi one way
Transmission (DSG/auto or manual): dsg
Failed turbo part number (if known): ----
Replacement turbo part number (if known):---
NY
2013 Passat TDI SEL
2013 SEL:
Miles on car at failure: 16,267
Build date: Feb. 2013
Corrective actions from dealership: replaced turbo, changed oil & filter, changed air filter. Inspected DPF & said was OK for now.
Outside air temps at failure: ~40°
Failure warning signs, if any: high-pitched whine when accelerating, then loss of power, then no power & blue smoke from tailpipe
Warning lights on dash/MFI: the two-loop glow plug/engine control malfunction light
Problems since replacement: TBD
Repair time: towed in Wednesday evening; picked up Friday afternoon
Any dealer divulged info on other incidents involving other failures: Tech. said he has had 4 in last 3 months (and a small dealer no less)
If not dealership, what oil was used/miles on oil:N/A
Did you baby your car or not: Middle of the road... no jack-rabbit starts. Mostly highway miles. Car parked in a heated garage at night.
Do you interrupt DPF regenerations: If so, not on purpose.... really don't know how to tell if it is in regen
How long is your daily commute: 10-ish each way
Failed turbo part number (if known): unknown
Replacement turbo part number (if known): 03L-253-056-QX (per invoice)
psd1
OR
3/21/2014, 6 more reported failures!
Data Compilation to date: 3/23/14
2012 Passats = 23
2013 Passats = 58
2014 Passats = 0
DSG: 33
6M: 33
Unknown: 17
From November 2013-March 23 2014 there have been forty eight (4) reported turbo failures.
Sure wish updating this thread was fun, quite honestly it is getting old. Good thing VW says that there isn't an issues with turbo failures. ;)
traveler103
Milwaukee
2013 Passat TDI SE 6MT
New member. Two failures to report. Will post twice.
Miles on car at failure: 15,150 miles. January 22, 2014
Build date: ? Purchased April 2013
Corrective actions from dealership: New turbo. They said different model number than the original unit, but couldn't give me the part number. Because I drove it to dealership, dumping oil through the exhaust, they also replaced the intercooler, EGR and DPF.
Outside air temps at failure: about -10
Failure warning signs, if any: slight whine from turbo for about a week before failure. Temps were VERY cold. (-7 to -21). The car failed in the evening, but that morning when leaving for work, the turbo made a split second choo-choo train whistle, but continued to function, although it felt like the turbo was free-wheeling and not really in sync with the actual boost. When it failed, there was a muffled bang, followed by a locomotive type black oily smoke rolling out of the exhaust. I was only 2 miles from the dealership, so I drove it there immediately. When standing on the throttle, it sounded like a nut rattling around in a can.
Warning lights on dash/MFI: Flashing glow plug.
Problems since replacement: Another blown turbo today.
Repair time: 13 Days.
Any dealer divulged info on other incidents involving other failures: "Yeah, we've seen a couple of those".
Did you baby your car or not: Baby it, until fully warmed up.
How long is your daily commute: 90 miles usually round trip
traveler103
Milwaukee
2013 Passat TDI SE 6MT Second Failure
Miles on car at failure: 17,510 miles. Failed this morning.
Corrective actions from dealership: New turbo. They told me that they didn't replace an oil line previously, and that was the reason for the failure this time.
Outside air temps at failure: about 24F.
Failure warning signs, if any: No warning signs at all! Just a sudden "phew" sound, followed by no boost. Wasn't even up to speed yet from leaving my driveway. No oil pouring out of exhaust this time, so I again drove to dealership.
Repair time:
Any dealer divulged info on other incidents involving other failures: This is funny. There was the exact car pulling into the service bay ahead of me. I listened as the driver told the service writer at the counter about his problem...it was the same as mine. Here's the funny part. He's is a sales guy at the dealership! He tossed the counter guy the keys and said, "I'm probably not your first priority right now, am I?"
Failed turbo part number (if known): 0020
TypeRod
Bristow, VA
2013 Passat TDI SEL Prem.
  • Miles on car at failure: ~16,900 miles; failure happened 3/22/2014
  • Build date: not sure/ leased in 8/2012 (2013MY)
  • Corrective actions from dealership: replace turbo, not sure of other parts
  • Outside air temps at failure: ~40+- 5 degrees
  • Failure warning signs, if any: 7 to 10 days prior has a split second loss of power, but no CEL/glowplug light, car was fine, then a few days later, turbo was sounding like a faint dental drill.
  • Warning lights on dash/MFI: flashing glow plug light
  • Problems since replacement: dealer still has parts on order
  • Repair time: n/a right now
  • Any dealer divulged info on other incidents involving other failures: said this problem was more common in the Northeast, and mine was the first he had seen. I live in VA. And VW is aware of the issue.
  • Did the dealership perform all maintenance and on schedule: they did my 10K service.
  • If not dealership, what oil was used/miles on oil: n/a
  • Did you baby your car or not:middle of the road
  • Do you interrupt DPF regenerations: not typically, probably did before I got my scan gauge installed, maybe after a month or two after i had leased the car
  • How long is your daily commute: when i first got the car, it was only driven 2/wk ~130 miles round trip each time, then a year ago, it became 5x/week ~12 miles round trip each time.
  • Transmission (DSG/auto or manual): DSG
  • Failed turbo part number (if known): don't know
  • Replacement turbo part number (if known): don't know
Will update when I get the car back, still no ETA for parts arrival
Herkguy
minneapolis
2013 passat SE sun/nav
2013 SE Turbo failing but did not shell itself
Miles on car at failure: 34500
Build date: 26 Sep 2012
Corrective actions from dealership: Changing turbo based on high pitch:)
Outside air temps at failure: 21F
Failure warning signs, if any: High pitch whine
Warning lights on dash/MFI: NA
Repair time: 10 days, ordered parts
Any dealer divulged info on other incidents involving other failures: Seen several
Did the dealership perform all maintenance and on schedule: Yes(10,20,30)
If not dealership, what oil was used/miles on oil: NA
Did you baby your car or not: baby to moderate 75-80mph on freeway
Do you interrupt DPF regenerations: 3 or 4
How long is your daily commute: 46 hwy each way
Replacement turbo part number (if known): 03L-253-056-QX. 0020
Thenixon
Maine, US
2014 Passat SE TDi
If you have had a failure, please post the following.
  • Miles on car at failure: 10070
  • Build date: 9/24/2013 (Model Year 2014, am I a lucky first?)
  • Corrective actions from dealership: Turbo replacement
  • Outside air temps at failure: 10-30 F. 30 when it got noticably bad, before that it was just noises.
  • Failure warning signs, if any: Cooing, whine and what sounded like a buzzing from the rear of the car the night before. One screech the morning of, then power loss, the dash light, and smell while I limped to the dealership.
  • Warning lights on dash/MFI: Glowplug light, for the last few miles
  • Problems since replacement: Still in shop
  • Repair time: 5 days (w/ weekend)
  • Any dealer divulged info on other incidents involving other failures: Said 'one other' 2014 car had a similar failure.
  • Did the dealership perform all maintenance and on schedule: Yes - I was on my way in for the first scheduled maintenance.
  • If not dealership, what oil was used/miles on oil: N/A
  • Are you the original owner of the car: Yes
  • Did you baby your car or not: No - highway commute, 75-80 mph. Moderate acceleration.
  • Do you interrupt DPF regenerations: No idea.
  • How long is your daily commute: 120 miles
  • Transmission (DSG/auto or manual): 6MT
  • Replacement turbo part number (if known): 03L-253-056-QX
I'm going to pick this up today, browsing this thread so I'll know what to ask when I do. I appear to be the first 2014 model year reporting in - I purchased it back in October of 2013. I was on my way to the dealership for the 10k mile service when the it started to get bad. Noticed some bad smells. I'll get some more details and post them when I pick it up this afternoon.
dgstrate
Detroit Area
Another 2013 Passat TDI Turbo bites the dust!!
2013 PASSAT TDI SEL Premium - Date of Turbo Failure: 03/13/2014, ~11pm
  • Miles on car at failure: 22,500
  • Build date: 01/2013 (purch. 01/2013) (edit - updated build date now that car is back)
  • Corrective actions from dealership: Replace Turbo, tube, DPF, EGR Cooler, Intercooler, oil feed line to turbo
  • Outside air temps at failure: about 20* F
  • Failure warning signs, if any: 22,500
  • Warning lights on dash/MFI: Flashing Glow Plug light (plus loss of power)
  • Problems since replacement: Unknown - still at shop ... *edit* - not so far
  • Repair time: 19 days (edit to actual time)
  • Any dealer divulged info on other incidents involving other failures: Dealer disclosed that VW has seen a number of these in "COLD climates like Maine." I am the 3rd or 4th they have done (edited to update more info)
  • Did you baby your car or not: Until warm, yes. Then driven "spirited-ly"
  • How long is your daily commute: over 60 miles
  • Failed turbo part number (if known): Older style turbo - replaced with revised part #
  • Replacement turbo part number (if known): VW03L-253-056-QX
usarmy132
NW subs Chicago
2012 Passat
Count me in
2012 Passat TDi SEL --- Date of Turbo Failure: 03-25-2014 @ 2:50 pm
  • Miles on car at failure: 32,000
  • Build date: 04-2012
  • Corrective actions from dealership: So far I was told new turbo, DPF and exhaust inspection for potential demages
  • Outside air temps at failure: ~30* F
  • Failure warning signs, if any: Whistle, puff, ton of white smoke, loss of power, oil dripping out of exhaust
  • Warning lights on dash/MFI: ---
  • Problems since replacement: Still in the shop
  • Repair time: Told few? days
  • Any dealer divulged info on other incidents involving other failures: Will ask
  • If not dealership, what oil was used/miles on oil: ---
  • Did you baby your car or not: Better than other once i had in the past, Yes
  • Do you interrupt DPF regenerations: Sometimes
  • How long is your daily commute: 50 miles
  • Transmission (DSG/auto or manual):DSG
  • Failed turbo part number (if known): Will ask dealer
  • Replacement turbo part number (if known): Will ask dealer
I will update my post once more information becomes available
dereksreynolds
Ohio
96 Passat TDi, 2 98 Jetta TDi
Another Turbo Failure
6MT
Miles on car at failure: 30500miles. March 27, 2014
Build date: ? Purchased July 2013
Corrective actions from dealership: New turbo, but now I have whining during acceleration. Planning to bring it back Monday.
Outside air temps at failure: about 35 F
Failure warning signs, Loss of power, check engine and Flashing glow plug.
Problems since replacement: Just got it today.
Repair time: 2 days
Do you interrupt DPF regenerations: not sure no way to know..
Replacement turbo part number (if known): see post below
dereksreynolds
Ohio
Turbo Part # ?
Here is part number from Invoice, 03L-253-056-QX, 03L-253-056--QU EXMANTURBO. Does anyone know which number is the new turbo part number?
psd1
OR
3/30/2014 update
Data Compilation to date: 3/30/14, eight more failures added this week, including the first MY 2014 failure.
2012 Passats = 24
2013 Passats = 64
2014 Passats = 1
DSG: 37
6M: 37
Unknown: 17
From November 2013-March 30 2014 there have been fifty six (56) reported turbo failures.
50pascals
Rochester, NY
2014 A6 3.0 TDI Prestige, prior was a 2013 TDI Passat SEL Plus
2013
41,529 on the clock
DSG
60 degrees outside
New York
build date unknown
Just finished climbing a hill.
95% of the miles on this car were highway speed, they are all generally long drives of 1 hour or more.
I only know of 3 regens interrupted
psd1
OR
From BadNewsMike:
He texted me this:
Here are the answers to the question on the bottom (in order) if you would like to post:***27,207 miles, (don’t know the build date), complete replacement with EGR, intercooler, etc. etc, 30º’s, a few minutes of a light squeal varying with RPMS, blinking glow plug light, then limp mode, 16 days, due to backordered parts, dealer acknowledged that they had seen a couple of others, dealer oil changes, just under 5,000 since last oil change, yes original owner, deliberately easy driving for the first 5,000 then typical (lots of highway, but still plenty of hills), I’m not aware of interrupting DPF regens, various distances, 6-speed manual, replacement part # 03L-253-056-QX.***Enjoy!
