I'd like to keep discussion of anything on this subject in the discussion thread, and data only in the data threads (one for general part numbers and build dates, and the other for failure reports). It's very difficult to mine data when it's scattered around with a bunch of discussion. It's also difficult to follow the discussion when it's taking place across several threads.I posted a question about this over in the discussion thread (which I assume is why you bought it up here) I wasn't sure if I should have posted it here or not. Sorry if I should have posted the question here. Sometimes it not so clear as to the difference b/t the discussion and data threads.
I disconnected engine breather to oil separator (actually it’s easy when it’s still new car, I felt so good after that the having new car hahaha), move the end of it with electrical connector on side and took couple pictures. Then at home I edited by zooming on tag, safe. That's all.I dont know how in the world you guys are getting the numbers let alone pictures off these plates. Getting old is HELL!
My replacement turbo is alsoinfo from my new turbo:
PART # 03L 253 056 Q
SER # PA50218790-00754
BW# BV40E-0020
Veedub did you this post:
http://forums.tdiclub.com/showpost.php?p=4104626&postcount=112
Hope you are older than me...I was born in 1939! No glasses either.I don't know how in the world you guys are getting the numbers let alone pictures off these plates. Getting old is HELL!
Part #: 03L 253 056 E V120
Serial #: 0E 50209889 00492
BW #: BV40 E - 0005
Build Date: 9/2012
Model Year: 2013
Where do I find that? I got 9/2012 from the plate on the door.Could you please post the exact day of manufacture?
Check my post here for how. --> http://forums.tdiclub.com/showpost.php?p=4114314&postcount=4Where do I find that? I got 9/2012 from the plate on the door.
2012-09-05could you please post the exact day of manufacture? Yours is the first v120 i've seen with build date of 9/2012. Mine was also built in september but i have a v150. Would like to narrow down when the change from v120 to v150 may have happened.
I ordered my car on May 25, 2013, and took delivery on July 13, 2013. I have 38,150 miles on her and she's doing fine, with no turbo "whine".
That has still not been nailed down...So which turbo is the defective one y'all have been discussing? V120? V500?
Let the record show that the B7's engine is different from the NMS's engine (CFFB vs CKRA).My 2.0 TDI CR 140 B7 Passat built 02/2013 came with turbo 03L 253 056 G
Be careful. You do not want to piss off the wise homosexual, or your posts will be deleted.My 2.0 TDI CR 140 engine code CFFB B7 Passat built 02/2013 came with turbo 03L 253 056 G
I think it would be safe to assume that the V500 is the updated version that is replacing the V120 and V150.That has still not been nailed down...
