This is a close up of my turbo oil return line, very corroded obviously. It is not leaking at present, but should I replace it? The problem is that it is very difficult to get at. Has anyone done this job with the engine installed?
Uugghhhh-that's pretty nasty-kinda looks like the ones on our cars here in the Northeast USA....I replaced mine on the Jetta I used to have a few years ago,but that was when I replaced the turbo. I don't know how big of a PITA it is w/ turbo on vehicle. You may have to remove turbo in order to get those severely corroded bolts out,as a socket or extractor probably won't be able to grab anything. I don't have the part #'s handy,but they did change the coupling that goes into engine block. Hopefully someone can chime in w/ part #'s......if you end up having to remove turbo-you may want to order another oil supply line for the turbo-they have a tendency to twist when trying to remove....
that is NOT going to be fun to get off at all. If its not leaking I would leave it, and just monitor it. Maybe try brushing some of the grit off to see if the metal still looks as though its maintaining its structural integrity, then if you are ever doing a job that requires turbo removal, just do it then.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
