Clark,
By all means, do not install a scavenger pump! I'm quite sure that is what actually killed my turbo. I won't go into all the details, but to get one set up properly is a nightmare, and they are an Un reliable electric item that can fail at any time, and when they do, so does your turbo. My pump actually ran fine and did not fail. What happened was, my turbo from the initial engine build was a remanufactured item. It leaked oil past the seals from day one. It was a bum turbo. On the long drive from North Carolina to Texas on the highway, the scavenger pump simply took too much oil away from the seals as many forums warn. This condition caused the shaft of the already crappy turbo to heat up and snap. So my turbo was crap anyway, and the scavenger killed it. A scavenger isn't the solution. I had my buddy pull another vnt15 from a Vw Sharan in the UK, a stock VW unit, the same as before but not a rebuilt one, and it's been singing wonderfully with zero oil leakage ever since, all over the west. Some guys with our installs have drain issues, some don't. The real solution, and what I'll do when I have the money, is use a BRM manifold that sits the turbo flipped upside.
