For the record, Jon did a great job w my tune and has been very helpful in this process.
Jon, so the logs are similar to before with the spiking. But we have a different turbo (last one was bunk from the start, this one isn't), and although the actuator is the same, it has been adjusted with this set of logs to initiate at 4 inHg, where as before it was 6 inHg.
These vanes are not sticky at all. I oven cleaner-ed the hell out of it before it went on, and those vanes and actuator tab move like silk now. That's not it.
And if the previous logs showed the same spike as now, with the actuator set to 6 inHg before and set to 4 inHg for these current logs, how would setting it to the middle at 5 inHg help?
I mean, if it was spiking at 6, and spiking at 4, gotta be something else, right? I just don't understand how more actuator adjustment is going to assuage the spiking. Help me understand.
So what is the commonality that is causing the spiking?
Intercooler is fixed better than before, as I went to town with a hammer and punch on those steel crimp teeth. It seems in there really tightly. I also fixed the attachement that was causing some wiggle, which had gotten that end cap loose.
I certainly need a new one, but I hate to buy a new (same inefficient) one, when I really need a whole different set up with a big all-aluminum FMIC (underneath like amosdoodle's van)....which will get done when I do the GTB1749VB. The entire existing intercooler set up is a bad design. fixing that now, and I am not going to have money to finish my trip!
On this trip, I try to go gently, but up steep, long, unrelenting grades at altitude, there's nothing for it but hold the throttle or not get up.
10-4 on that 007 IAT monitoring.
