neb32
My MK6 JSW threw a CEL.
I put the VAG Com on and it said there was an issue with the turbo actuator. I went through the troubleshooting and determined that the actuator is the issue. I cleared the codes and continue to drive it.
The turbo had been replaced with the dieselgate emissions update. I went to the VW dealer to see if this was something covered by the warranty. They told me it most likely would be covered. I could replace the actuator my self, but if VW does it under warranty, I will get a new turbo. But they will not warranty it unless it shows the CEL that was cleared. So I should not have cleared my codes.
Is there a way to manually get the actuator to throw the code I had previously had?
I can feel the turbo output is no longer smooth and my MPG is down.
Thank you in advance.
