NSTDI
I disagree, 2 things, why not design a stronger turbo, they are using a new one in the 2015, they spent the money to design it, they design new turbos all the time. Having TDI's with turbos failing is not good for business and getting the turbo fixed is something VW would want to do.I disagree because this isn't a new problem. They have failed design a more robust turbo and keep installing the same piece of junk. I'm sure the DPF has caused problems for all the brands. But I would bet the turbo failure rate is much higher with VW than most others. There is most likely a VW employee in an office who ran the numbers and decided it will be cheaper to constantly replace turbos than to redesign it to be more robust. I would gladly have payed a few hundred $$ more to have a much better turbo in my Passat. That being said... no issues what so ever for me![]()
Second, based on the number of reported failures this past winter on this site being down significantly, it appears the turbo has been improved? Late 2014's and 2015's have not been failing at the same rate as the earlier turbos.
I lost mine at about 40,000 KM's, replacement still working at 84,000 KM's.
Losing 5 turbos in one car makes you wonder how good a job was done cleaning up the mess after each failure. A significant majority of owners never lost their turbo.
Don
