Chris B
I made an interesting observation last night while unloading my new Turanza LS-H tires on my Avus II wheels from the wife's CRD last night. They BARELY fit into the rear cargo compartment. The door had to be really squeezed shut. This is with the tires standing upright and facing front to back.
The old tires, the stock Michelin's, which were down to about 1/8" tread, fit easily with slop to spare. Both are 196/65-15 size.
Granted, they had a lot of tread worn off, and the Turanzas have some REALLY deep tread, but there seems to be a marked difference in rolling diameter. My Firestone Winterfire tires also seem larger in OD. Haven't measured those, tho.
I'm wondering if this diameter difference is really the source of the mpg hit most people see when switching from the Michelins? A larger OD tire will roll farther for the same indication on the odometer, giving 'measured' poorer fuel mileage.
Maybe the stock tires aren't so low in rolling resistance after all, but merely made to a smaller OD range than 'regular' tires of the same size to give the *impression* of better fuel mileage? Conspiracy?
Anyway, just stirring up some thoughts. I'll mount the Turanzas this week and bleed the brakes with my Mity-Vac at the same time, they are quite overdue for a fluid change.
Chris
Chris
