Yeah, me too. Granted, Malone is on vacation this week.I think you need to ask that question to your tuner. I am surprised they are not being more supportive.
Yes. And the outlet, egt spacer, ect. All of the the proper cr170 bits.Did you get the cr170 plastic intake pipe with the turbo?
You and Madness can take a hike.I think you need to ask that question to your tuner. I am surprised they are not being more supportive.
You received a reply from Mark Malone through me, that should be good enough. (It's not)I felt Kerma was commenting on the lack of MaloneTuning presents on this thread, not you. Which is what I replied to because nobody from MaloneTuning had commented at that time. Nor had I recieved a reply from MaloneTuning on an email that I had sent the other day.
You're listening skills are lacking, it was cracked before the tune and turbo upgrade, he'd be happy to verify that.You also had another customer that cracked his head after getting a stage 2 tune from you.
Sure, buy a Flashzilla or go see another dealer, I'll give them the file free of charge, you can pay them for their labor.Lastly, you still owe me atleast a stage 3 tune. I bought the CR170 when you had that sale "Buy a cr170 and get a free Stage 3 Malone tune uprgrade." That was if the buyer already had a stage 2, which you and I both have confirmed that I do have.
How was I suppose to know that a reply was from Mark from you never told me? I dont even know which reply you relayed from him.You received a reply from Mark Malone through me, that should be good enough. (It's not)
You have decided that, "There is not a problem with your car because we have not suggested a test that pinpoints the cause of the problem." It doesn't work like that. You'd rather argue that the tune should be written for a 4 bar map sensor, that's the cause of your boost lag off the line, the car only has a 3 bar map sensor and tune for the 3 bar. The 3 bar map sensor is confusing the car and causing the lag!
You are not qualified to be testing the car and determining the results. Last week I showed you what a mityvac was and gave you a general overview of what it is and how someone could use it to do diagnostics on a car.
That is not what you said.You're listening skills are lacking, it was cracked before the tune and turbo upgrade, he'd be happy to verify that.
What question of yours did I not answer?You sent me a PM when you started this thread titled "I hear you are the CR170 Guru.", I took the time to read it and give you useful info to check into, attempted to help you out but you never answered my question, now I see why, because the problem is the same and you're still trying to pin it on Andrew or Malone.
It turns out that everything under that hood needs to be in question - especially the cams and the work. If you'd lay off the weed, maybe this thing would have been put together half ways correctly. Pointing fingers does you no good and only annoys people that don't have any obligation to help you fix your hardware problems or even help diagnose it for free. These tunes have been installed on hundreds if not thousands of cars and they all work just fine, its extremely rare that the tune is the problem.
I tested just as you instructed and you said it was within spec. You determined the results.You are not qualified to be testing the car and determining the results.
Im not just blaming the tune. Im on here asking for comparisons, asking for other tests that can be ran, asking for other groups to log.There is no way it's the tune. Something mechanical is wrong with your car. Sounds like these guys went above and beyond trying to help you with this. I do hope you figure it out, but blaming the tune needs to stop.
Are you saying I'm the 1st person to ever re-use a cam?This makes him the first ever to do this mod...what should we call that, "Madness's Old Cam Mod"?
It is fairly unusual if the head came w/ brand new cams. I think it's fairly safe to say the tune is absolutely not your problem.Are you saying, I'm the 1st person to ever re-use a cam?
Unusual, maybe, but far from the 1st person ever.It is fairly unusual if the head came w/ brand new cams. I think it's fairly safe to say the tune is absolutely not your problem.
Let's face it- you're an amateur. When GDM did my install I didn't have boost leaks, coolant leaks, any leaks, or any problems. Sometimes it's best to just let the pro's do their thing.Yet when I asked, nobody suggested I use the new over the old one. All I was told was that it wouldn't make a difference.
There was speculation that the old cam was better because of the lash gear but nothing solid.
I'm not only saying the tune is problem. In my OP, I said Im not claiming to be perfect but that I do have and used tools that not even my dealership has.
Thats subjective.He had a Stage 2 custom tune working great
The 1st part of this is a total lie. As I stated previously, Rich helped me with it. But I'll show him what you think of his work.He also installs a CR170 by himself and and supposedly did it correctly....but breaks down enroute to our shop because he lost all his coolant half way through his journey
Thanks for takin a look at 'em Keir.
I figured you would come to the same conclusion and not think its the tune.
Do you have any clue as to what could cause it? Or where else I should look? Tests I can run, groups I can log?
How'd the MAF actual look to you? Do you know why the MAF is reading high?
Kerma mentioned the cam timing, I'm not sure if he meant internally or externally but I checked the external gears and everything is on point.[/QUOTE
How many miles on the car?
