EDIT I redid the turbo actuator adaptation. Duty cycle is 16-17% & 99.4%. MAF spec, at idle, is 200-350mg/h. My MAF is reading 470-480mg/h. Unplugged, its ready 425-430mg/h. I tried a known working MAF, same result. His car with his MAF & my MAF are reading 260-270mg/h.
I recently put on a new head and CR170. Before I had the stock cr140 turbo with a Malone 2.5 tune and it was fine.
After putting on the new head and CR170 turbo, it felt the same, just as punchy as before. Figured I just didnt notice the difference on the same tune with the different turbo.
After ironing out the kinks, it drove fine. Same MPGs and no codes.
Today I went to get the 3.5 tune, swapped the EGT sensors and it was really laggy. After pulling logs the tuner said it was something mechanical. He put the 2.5 tune back on and it feels like I have less power than before he tried the 3.5 tune.
He believes there is something wrong mechanically even though there are no codes or other such tell tail signs.
I feel very confident that I did everything right. Used quality tq wrenches all around (craftsman and snapon), didnt reuse any stretch bolts, gaskets or seals. Im not saying im perfect or that I didnt mess something up.
How can I confirm if there is or is not something mechanically wrong with my turbo?
I just remembered when I did the turbo actuator adaptation, I had a boost leak. I fixed the boost leak and didn't preform the adaptation again. Would that throw the tune off and make the tuner think there would be something mechanically wrong?
Thanks in advance.
Thanks in advance.
