Nuje
- Joined
- Feb 11, 2005
- Location
- Island near Vancouver
- TDI
- 2002 Golf 6MT; 2015 Sportwagen 6MT; 2016 A3 e-tron 6DSG
Feels like this is about 15 years late, but since I couldn't find anything really definitive for installing TT seats in a Mk4, I figured I'd write this up for posterity, if nothing else.
First up, the issue. Mk4 VW seats mount into the car via two side rails - the seats have little wheels and sliders that run in those rails. The Mk1 TT seats, however, are more typical in that they'd bolt straight to the floor of the vehicle. And if you did bolt these seats straight to the floor of your VW, you'd be sitting very, very low.
My first thought was to find something that I could bolt to the floor and then mount the seats to that - and found (thanks to slick winter roads and people around here who don't believe in bespoke winter tires) a road sign post or two lying in the ditch that would probably fit the bill. Good and strong, anti-corrosion treatment, many holes at regular intervals. But....that would mean drilling through the floor pan of the car and hopefully not hitting anything crucial, so....
Plan B: Found some mounting brackets for just such a purpose. Not cheap however - at $185 for just one ($370, thus, for both front seats) from PlantedTechnology.com. Similar (cough-cough) options seem to also exist at significantly cheaper prices ($150 shipped for the pair) - eBay link, so it'll probably expire, but the seller is mitstocks.
Here's a video that explains (with video quality that makes you really appreciate the HumbleMechanics for the world) the basic functionality and installation process in a Mk4.
Given that both 5'11" me and 5'4" Mrs. Nuje (maybe?) will both drive this car, I wanted some seat adjustability and the TT seat rails have front anchors that pose a bit of a problem, some metal-moving had to occur.
The TT seats front bolt anchor points are bent forward at a ~45° angle, and gusset-reinforced.
So, out came the M18 angle grinder with cutting wheel and we hacked away that gusset.
Then, I supported that end of the rail by jamming a piece of 2x4 between the rail and the seat bottom and hammered the formerly gusseted extension flat.
At the other end of the rails, there's a locater pin that extends upward and just barely gets in the way (or not quite) of that mounting plate (sorry - no photo, but you'll know what I'm talking about if/when you get to this), so I ground away a bit of the corner - like maybe 2mm in each direction, just so I had a little wiggle room if needed.
After that, it was just a matter of figuring out how to bolt it together. I went with a heavy-duty washer (the ones that come with the 6point axle nut work great) on that gusset-removed area, along with the bolts/nuts from bottom mk4 shock mount (M10x1.5). You can't mount the plate directly to the seat rails because the spring-guided pins that lock the seat in place when you adjust front/back need roughly 5-8mm of headroom.
So, I stacked three M10 washers between the plate and the rails. At the front (gusseted) end, I went with the bolt head through the rail, through the washers, through the plate, then another washer and then the M10 locking nut. There was maybe 20mm left sticking out, so I just cut those off with the cutting wheel.
At the back (notch-cut) end, I re-purposed the M10 washered bolts that hold the Mk4 upper rear shock mounts - perfect length and should be plenty strong. Same M10 locking nut as the rear bottom shock mount. At that end, I put the bolt through the bottom of the mounting plate, then used a magnet to get the nut into position (it's inside the seat rail, so space is at a premium), then wedged a screwdriver in there to counter hold as I tightened the bolt.
Finished product looks like this from the bottom (back is up top, front of seat at the bottom). You can see the locating pins that are kinda / maybe in the way in this photo; maybe didn't need to grind anything away, but in dry-fitting things, having a little room to move helped.
The little tabs at the bottom mount up behind the lip where the OE seats bolt; for the rear, there are two little "tongues" that slide into the car's seat rail side "slots", and then again, those rear upper shock mount bolts are the perfect length and threading to lock those in place.
Wiring:
The good news is that the wiring is the same on these seats as in the OE seats.
The bad news is that the wiring connectors for the airbags and seat belt tensioners/locks (or whatever that other one is for) are different. TT on the left (seat side), Mk4 Golf on the right (car side).
Green connector is the seat heat (no change necessary); red is the seatbelt thingy (two wires on passenger side, four on driver side); yellow is the airbag (three wires on each sides). The colors matched up, so it was pretty straightforward. (Of course, I stood back when I first turned the key; YMMV
At first I thought I could just pull the terminals and move the existing wires to a VW Mk4 connector, but alas, the wire terminals are different shaped between the two cars. So, it was snip-and-heat-shrink-butt-connect.
The finished product:
Wiring:
