CLR that bad boy. I've done at least a dozen cars where they were told to replace the heater core due to plugging. Its worth a try over freezing, waiting and/or the cost,the crud that builds up in them is like concrete
You don't run CLR thu the whole system, lol.vw covers it free, plus clr is hard on the head gasket and water pump
See above. I've done dozens of plugged cores, worked great and lasted for years. Usually, it only comes back if you use the wrong antifreeze or use sealers.Yup, pretty much a no brainer when it's warrantied. You could isolate the acid flush to the heater core alone, but it would be a temporary fix at best.
had a heater cor replaced due to the no heat on passenger side approximately year ago...Now that colder weather set in this winter i'm seeing this problem again?!?! It was fine up until few days ago....VW dealership replaced the core under warranty last time and i'm gonna call them tomorrow to see if they are going to replace it again....hopefully I don't have to pay anything....what a stupid design Jesus Christ.....
regardless of mileage???replaced under warranty...apparently it is warranted now until 2023!!
yes...and this is in Canada....regardless of mileage???
That's too much work IMO....in no other cars have I ever done that nor I will in future....checking the coolant level is as far as I will goFrom a proactive perspective, if you monitor the pH of the coolant and change it when it gets down to 7.0 (which is neutral, pH should be slightly alkaline), you may avoid the situation where the coolant turns acidic, erodes, and leaves deposits is small/tight places (like the passages within a heater core). My 2015 TDI with 11,000 miles had a pH of 7.0 when I got it, without any heat distribution problems (yet), and I did a coolant flush and refill.
OK. Just so you know, for your car, many of the aluminum items in the cooling system were assembled with excess flux remaining as a residual contaminant which over time causes the alkaline level in the coolant to become acidic and attack/corrode metals in the cooling system. Most other makes didn't have this assembly issue, but many VW's in this era did. You can either understand that and try to be preventive, or do as you wish and possibly (likely) have a replacement heater core in your future with contaminants throughout the cooling system caused by this corrosion that could get to and impact a new replacement heater core in short order (if the flush wasn't done properly). IMOThat's too much work IMO....in no other cars have I ever done that nor I will in future....checking the coolant level is as far as I will go![]()
Some people are just too lazy or stubborn to fix things they feel they shouldn't,OK. Just so you know, for your car, many of the aluminum items in the cooling system were assembled with excess flux remaining as a residual contaminant which over time causes the alkaline level in the coolant to become acidic and attack/corrode metals in the cooling system. Most other makes didn't have this assembly issue, but many VW's in this era did. You can either understand that and try to be preventive, or do as you wish and possibly (likely) have a replacement heater core in your future with contaminants throughout the cooling system caused by this corrosion that could get to and impact a new replacement heater core in short order (if the flush wasn't done properly). IMO
Yes.Always had the replacements done at the same dealership?
