I think core clogging is going to be a recurring issue unless they address the excess flux in the radiator. If enough repeats happen, expect to see a radiator replacement added to the TSB.
Does VW cover out of warranty vehicles when a TSB is issued?Having an out of warranty 2012 NMS, I'm curious why the 2012 isn't cited in the TSB.
VWOA refused to cover the cost of replacement for my 2013 because I was "too far out of warranty at 75k miles and should have brought the car in last winter when the problem first surfaced."Does VW cover out of warranty vehicles when a TSB is issued?
irishrob: I don't think anyone here would refer to any VW employee as an "advocate." They are all VWoA employees, and would only be functioning as "advocates" for VWoA, not the consumer.
He introduced himself as "A Consumer Support Advocate"
Many others have had success in VWOA covering the cost though.
I absolutely agree. Unfortunately, Volkswagen rarely works like that.I've had Toyota perform TSBs at no cost because they extended coverage for the issue (like 7y/75k).
If the problem is common enough to issue a TSB, VW failed to deliver a reliable part/design, and should cover the repair within a reasonable time frame.![]()
Thanks for the clarification. All I can say is...BWAHAHAHA!!!!![]()
This is the essence of the situation. We got a 10/120K extended warranty on the heater core on our '13 Passat (we also have one on the turbocharger and the DEF pump), but from what I've read in this forum, there are other '13s that don't qualify.Now this is turning out different from I expected .... <snip>
Apparently some MY cars were covered by an extended heater core warranty, but mine was not and I am out of luck.
<snip>
If that's the case, it would help explain why our 2012 has had no problems after 113,000 miles.early 13's use G12 and late 13's like mine use organic G13 that separates and clog's things up. it really sucks, driving in snow, completely fogged up windows- awesome!
Just have a rad shop back flush it.had a heater cor replaced due to the no heat on passenger side approximately year ago...Now that colder weather set in this winter i'm seeing this problem again?!?! It was fine up until few days ago....VW dealership replaced the core under warranty last time and i'm gonna call them tomorrow to see if they are going to replace it again....hopefully I don't have to pay anything....what a stupid design Jesus Christ.....
