TDIJetta99
haha, he's in NY... Probably not interested in traveling to Tennessee for service.. I'm about 4 hours away, which is a little far even... I have a couple of tdi customers that come down from Rochester anyway
Updated - I kept the same phone number, since you didn't mention a change.Can a MOD please update my map info? I am now at 1107 S West St, Suite H1, Wichita, KS 67209.
There is almost certainly nothing wrong with your turbo. Limp mode is produced or generated by the engine control module (ECM) to protect your turbo!Any TDI trusted mechanics in the Seattle, WA area. My 2003 Jetta TDI keeps going into limp mode when accelerating up a hill. I've read several posts but I don't have the skill to work on the car myself and don't want to pay for a new turbo the dealer suggested unless it's the only option.
ECM and ECU refer to the same engine computer. When it generates a limp mode condition, it is doing what it was programmed to do. This is not a fault with the ECM, and it does not need to be replaced or repaired.I searched for ECM and couldn't find much except it's sometimes called a ECU. Any posts about it. Is it an individual unit that can be replaced or worked on?
Thanks a bunch. Phone number is still the same, but I forgot to mention the website is now www.EuroTecWichita.com:)Updated - I kept the same phone number, since you didn't mention a change.
If you look at the official "Trusted Mechanics List" (link in the first post in this thread and below).Anyone in Calgary folks
I have no idea who listed the "mechanic" for Alaska, but I have no idea what the place is.
I recommend highly:
Arctic Import Repair
512 W. International Airport Road
Anchorage, AK
907.277.3399
ww.arcticimport.com
Agreed! Christian at:Been lurking here a while and needed to take my 2000 Jetta in for some work in Houston. Didn't see any Houston mechanics listed on the map but found this guy:
http://www.vdubautohaus.com/
V-DUB Autohaus
20815 H and R Road, Houston, TX
(281) 235-5934
I just needed a new A/C compressor but was impressed with how helpful he was.
The guy that runs it is named Christian, he worked for VW for many years as a new car tester and was in charge of the shop for a major dealership most recently. He let me stick around in the shop as he worked and pointed out a lot of things that might need work soon and what to look out for later on and things like that. He might be worth adding to the map for anyone in the Houston area needing work done.
Every VW owner needs to find an independent repair shop that has knowledgeable and experienced technicians... and V-Dub Autohaus might be just such a place.Agreed! Christian at V-DUB Autohaus...Was recommended to me by another member. I have talked to him quite a bit over several visits and the guy is great! Just had him do a timing belt and water pump yesterday. Definitely a trustworthy and knowledgeable mechanic. Can't say enough about him. He will not sell you something you don't need. I will be going back to him for more scheduled service soon.
Agreed!I also endorse Christian's shop in Houston.
I know him personally and he has many years of TDI experience while in Germany (his homeland). His shop is about a year old and has quite a following in town. Members here are very satisfied with his work and ethics.
I recommended his shop to my business associate for work on his son's car when he split the oil pan and cracked the bell housing last Fall. The shop did a great job and the parts were OEM.
I don't know what else to tell you folks who make the "decisions" on who gets on the list. If this is not sufficient to get his shop added, no big deal as we have already passed the word in town here on the regional thread.
Cheers,
Tony
Gates, ContiTech, and Dayco are all quality timing belt manufacturers. I don't know about SKF roller/idlers -- the only time I ever had a problem with one was when it was not made by INA. I thought all tensioners were made by Litens.I received a gates timing belt, a continental accessory belt, SKF bearing, INA tensioner, and all the bolts needed from idparts.com as well as a graf metal impeller pump. I decided against the metal impeller pump and worked with Peter at idparts.com to try to get an plastic/resin one with no luck from the suppliers on his end. I am thankful to Peter for refunding my money on the metal impeller pump!
Christian was able to supply me with a plastic/resin impeller pump from Graf and made in Italy. He used all my other parts and also noted that he would have recommended the continental timing belt instead.
