kcfoxie
I requested the engine be removed. I didn't want to take any chances, and I was looking at complete removal of the EGR system.
We decided not to, as we were able to modify the Van Gough. I have a BEW Van Gough and I don't buy that you can get an angel grinder up on the block w/out the engine out of the car.
The block of the vehicle had to be modified more than a touch to make the BEW Van Gough bolt up. There isn't enough room to grind away at the "fins" on the block from casting to get the bolt holes to line up. The engine needed to come out.
Another shop said they could do it in the car, and said there was no need to remove it, I said BS and went elsewhere.
You're welcome to be entited to your opinion, Mr. There was no 5-speed Beetle with a BEW motor.
The point is, 11k later, nothing has broken free and everything works. What more qualifies you than complete removal of an engine and reinstallation and it all works on the first go?
