Trusted TDI Mechanics - By State
Big10
Little Elm, TX
2015 GSW TDI SEL
Please note that Brian Hague in/near Little Elm, TX (DFW area) sold his business a few years ago to Robert Pierce (nka Pierce Family Automotive).
Brian also previously moved his shop to Denton and Robert has most recently moved it again to:
403 Fort Worth Drive
Denton, TX 76201
214-257-8221
Robert (and now his crew) are a VW/Audi shop but work on all makes and models.
Lead_Sled
Lou-Z-ana
‘14 Jetta Sedan
Looking for a place in the Austin / San Antonio / Houston Texas area.
Finally found “runonbeer” website and says he moved away a few years back.
After my dieselgate warranty expired a few months back, I’ve collected my parts, but just haven’t found time. Probably will not have time with my work schedule.
Here’s what I’m looking to do:
- DPF/EGR delete……have buzzken pipe, Malone stage 2 tune with CP3 upgrade
- CP3 upgrade kit
- 2Micron filter install
- Timing belt change
Currently at 90k miles.
  • Like
Reactions: Ton
Flybuzz
Virginia
Golf Sportwagen SE TDI 2015
Fallen Automotive in Sterling, VA has moved 7 years ago to a nearby place located at 22585 Markey Ct, Sterling, VA 20166
The list needs correction on it. The phone remains the same
hskrdu
Maryland and New England
  • Like
Reactions: Ton
schwinn guy
Chicago 'burbs
2001 Golf GL 5 speed
Good snowy morning from Chicago.
Anyone heard from Matt Miks recently? Is he OK and doing TDI work still? He did my timing belt on my 2001 TDI and local to me and was trying to go to him again as he did great by me and has a good reputation here on the forum.
Thanks!
Greg
SeattleMK4Golf_BEW
Seattle, WA
2006 1.9 TDI Golf (BEW)
Hello - the landscape of auto garages in the Seattle area has changed a lot since this thread was active. Anyone have any recommendations for mechanics who will work with aftermarket parts?
mcawsm4565
PUGET SOUND
2015 jetta tdi
Any tips for opening the list/ Map? The map is nothing and the list just always says no connection? Alternatively anyone know someone close kent wa? I've seen some reccomendations in redmond, tacoma, and seattle but hoping there's one closer to home.
  • Like
Reactions: Ton
AndyBees
Southeast Kentucky
Welcome to the TDI Club
Maybe it is because you are a new member.
The List and Map both work for me.
I'd drive up to Westfield MA to 413 Motors. Mike McCann knows these cars backwards and forwards, is reasonable, and gets work done on time.
pyromancer
Seattle, WA
2001 Jetta TDI
Mouse Meat
4732 S. Washington St. Tacoma, Washington
They installed a 100k timing belt kit on my 2003 jetta and I have nothing but good things to say about them. I brought them the parts i had purchased from a trusted vendor, and where most shops would charge me extra for bringing my own parts they did not. I also brought them new vacuum lines to install which they advised me against since mine were fine. all in all they changed the tb and cleaned the intake for just under $400 so about $700 total including parts which I dont think is bad. I am extremely satisfied with the service I recieved and will recomend them to anyone who needs any vw work.
@SeattleMK4Golf_BEW had these folks do a timing belt, cam and some other stuff for him. I took a look at his car today to help him try to figure out a rough idle situation. The torsion was off, cam sprocket center bolt was not torqued to spec, his coolant reservoir was overfilled, and it looks like they may have messed up on installing his cam seal. He also had a bad in tank fuel pump, and a failed thermostat they failed to diagnose or recommend he replace. I couldn't get a good look at where the oil inside the timing belt cover was coming from given the time I had today to be positive on the cam seal. Although there's not a lot of places for oil to get in there that high up... With what I saw today I was thoroughly unimpressed, and would have the complete opposite recommendation. Here's hoping his issue is a valve cover gasket or something else that doesn't require basically the same labor as a TB job so he doesn't have to take it back to them.
SeattleMK4Golf_BEW
Seattle, WA
Sadly, I must say that everything that @pyromancer wrote above is completely true. Totally disappointed and frustrated by what was revealed to me yesterday as we popped the hood and took a look together (step by step the whole time). F*******g S** t !!!!!
ThePupa2000
New Jersey
2015 Jetta TDI
can anyone recommend a trusted TDI guru in the NJ area? i am located in central jersey but am willing to travel. I am looking to have my timing belt changed. I have attempted to reach out to a few people on the trusted list already, but have received either no reply or i have been informed the mechanic is no longer working. Thanks in advance!
You might want to reach out to Mike Hevner at M&M Auto/Cycle in Montague, NJ. 973-293-8588 Does a lot of work on TDIs.
Iowa TDI
IOWA
2014 TDI Vert Beetle
Joetown Auto near Kalona, Iowa. Just quoted me $950-1000 for timing belt and water pump, coolant change for 2014 Beetle TDI. All he does is VWs, ask for Wally. Good guy, small shop.
TornadoRed
This shop was mentioned several years ago, but we never got any feedback positive or negative. The Google reviews are good. Not many miles SW of Iowa City, west of Hwy 218.
Iowa TDI
IOWA
Wally has been doing VWs longer than most. He is more of a word of mouth shop than anything. I dont think he needs to advertise.
TornadoRed
Being so close to Iowa City, and not that far from Cedar Rapids, he is in a prime location. Probably not the best, though, for someone who needs to drop off his car.
teddibear
Marysville, wa
Volkswagen golf tdi 1.9L
Here are a few in Seattle WA that I have heard good things about (though this is not my firsthand experience--nobody touches my cars except me!):
AutoVice in Lynnwood
BugAid on Aurora in North Seattle (have talked to/bought parts from these guys and like how they work)
Fine Tuning Performance (have talked to owner and seems to know his stuff)
I'm in washington by everett an need to find someone that knows about volkswagen golf 2003 1.9L tdi
