Trusted TDI Mechanics - By State
gmcjetpilot
Memphis TN
2010 JSW TDI DSG Matalic Grey
Please update Wolfsburg Automotive, new address at 5331 Summer Ave, Memphis, TN 38122 , upgraded larger shop about 2 or 3 yrs ago. There is no better place in the Memphis, North Mississippi, SE Arkansas for VW TDI than Wolfsburg in Memphis TN. They are an Independent Audi/VW/Porsche repair shop with Factory Trained Techs, who can do routine maintenance to big repairs, troubleshooting and restoration. Their prices are fair and Jim Boyd and Patrick Findley are the owners and gear heads. Why do I recommend them? Dealing with them for 10 yrs never disappointed. The only issue I found is they can get booked out for a few weeks during busy times of year. However they have more Techs than the Local VW dealer. They are good.
5331 Summer Ave.
Memphis, Tn 38122
P: 901.761.3443
F: 901.761.3432
PS please put them on the STATE MAP.
xcmer
Belchertown, MA
Jetta MK4
Recommending
Independent Volkswagen & Audi
5205 E 22nd St, Tucson, AZ 85711
Phone: 520.747.0044
They took my business after Stuttgart Autohaus, which I found on the list, told me they no longer service cars older than 2005.
Chris talked to me about the work they did and the reasoning behind decisions in some depth. Although I've only gone there for diagnosing shifter problems and a bushing replacement, they were knowledgeable and obviously familiar with my ALH.
To add a note about Stuttgart Autohaus (614 E Glenn St, Tucson, AZ 85705),
Stuttgart changed hands some time ago and regrettably the work I've gotten had declined as well. A few months before they said "nothing older than 05" I brought my 2001 jetta in and asked to replace all worn vac hoses, and ended up replacing all of them myself as several visibly cracking hoses were not replaced and one had been replaced with a bit of fuel line.
Judging by the reviews, I'm sure they still do good work on newer cars, but I would be a little wary.
  • Wow
Reactions: Ton
hwiskow
Eugene, Oregon
2002 Jetta TDI, 2002 Jetta Wagon TDI, 2000 Beetle TDI
Looking to be added to the Member Recommended Mechanics List or have someone you want added?
There are many that ask how does one get on this list.
I will do my best here to help you understand what it takes.
After reading this, if you have any further questions, feel free to PM me.
First and foremost this is not a list for any and all mechanics.
If you are a TDIClub Vendor, this does not mean you bypass the rules below.
It's for Member Recommended Mechanics, specifically TDI Specialty mechanics.
The formula to qualify for this list is quite simple.
You must prove competent in repair & maintenance of our baby's that we paid a lot of hard earned money for.
You must use the right tools.
You must do things BY THE BOOK as VW intended.
This means using the right tools.
Secondly, you must not go replacing a turbo thinking its going to fix the car. You need to KNOW it's going to fix it. This is our hard earned money, remember? If the turbo is truely the problem, does the whole thing need replaced? This is an assembly. This means lots of parts on there that could be replaced rather than the whole assembly.
We look for member vouches on a mechanic to get on this list. How many we need may vary. If we have a high level technician on the forum here that refers a mechanic, chances are its going straight on the list. Otherwise we need more than one person to give a good word.
If you are referring, please be sure to have the confidence in whether this mechanic is doing things by the book and using the right tools. This means you gotta have knowledge of the manufacture's procedures yourself.
Also, be descriptive on why you are referring. Be sure to cite facts on proving to us this person should be on the list. Let us know what the symptoms were, what work was done, what tools were used, how much was charged. Does this shop specialize in only TDI’s, all European, any car on the road type shop.
Please utilize the following format when listing the shop:
ABC Shop
123 Road
City, State Zip-code
(123) 456-7890
ABC@shop.com
Any short blurb you may feel is relevant for the list
BTW, please post this rather than private message so others may comment.
Edge Motorsports
4065 W 11th Ave # 22
Eugene, OR 97402
(541) 242-3343
edge-motorsports@hotmail.com
This is more of a request to update shop name and location for a trusted TDI mechanic already showing on the map.
Springfield German Import is no longer open. The mechanics that worked there opened their own repair shop in Eugene Oregon.
They are the only mechanics in the area that I trust with my VWs. They have all the right tools and all the right knowledge. They specialize in VW, Audi and BMW but will work on other vehicles if needed.
Please consider adding them to the trusted TDI mechanics map.
  • Like
Reactions: Ton
