Troubleshooting Strange Engine Codes/Problem
alhdude
London Ont
2001 Jetta 5 spd TDI
Hi all!
My 2010 Jetta tdi dsg with the cjaa engine set these codes;
P13D6 was the glow plug code implausible signal static
P0341 camshaft position sensor circuit - code intermittent
The cyl #3 glow plug was replaced and the cam sensor.
P020C cylinder 3 injector timing - intermittent
I can drive the car for a for days with no codes
Before when I wiggled cyl #3 glow plug connector at idle the engine shudders , but if I leave it alone it idles fine. Now it is fine and doesn’t shudder.
none of these codes sets limp mode
Or causes the car to run any differently.
I feel like I have an issue with the engine harness. I can drive the car for hours or days with no codes.
anyone have any ideas?
