oldpoopie
- Joined
- May 14, 2001
- Location
- Portland Oregon
- TDI
- 2001 golf gl, 2006 jetta, 1981 ALH swapped rabbit pickup, 1998 beetle
So a customer brought an alh to me for a timing belt/cam/lifter job...the car when cold also smokes and coughs and is throwing a cyl 2 misfire code intermittently.
1st thing I did was compression test
Cyl 1 420
Cyl 2 385
Cyl 3 390
Cyl 4 410
Then swapped in a spare set of injectors..
no change
Then I did the timing belt, cam, lifters, oil change, coolant temp sensor, thermostat, and new injection pump.....
No change
I ran it from a separate fuel source....
no change
I swapped in a spare crank position sensor....
No change
Cleaned the intake manifold AND the ports in the head (very dirty).....
no change
Did a leakdown test. All 4 cyl test between 6% and 10%
Im really at a loss on this one... on cold start it knocks and pings like crazy.... hot it smooths out. Smoke is all white unburned fuel smoke, NOT oil....
Cyl 1 420
Cyl 2 385
Cyl 3 390
Cyl 4 410
no change
No change
no change
No change
no change
