UHF
I have a VAGCOM with the HEX-COM interface. It doesn’t seem to be functioning properly. I own a 99.5 TDi Jetta, 5 speed with the A$ chassis and VNT turbo.
Here is what I have done.
I turn the car to the run position, but did not start it.
Turned on my P2, 300mhz computer plugged in the hexcom and then plugged it into my serial port on my laptop.
Then I went to the following menus:
Control module finder:
Options
Test COM port
It is found on COM port 1, I saved.
Went to control module finder and let it finish.
I found only a few addresses.
01
03
17
33
3F
And 46.
I then went to select and chose 01-Engine. It does the search per the Internet description:
This screen will appear when VAG-COM is attempting to establish communications with a Control Module.
Some information also appears in the controller info area, but it immediately goes back to the previous screen “Common Modules” by itself. I cannot and it will not let me select any functions, basic or advanced. The boxes go from gray to black letters in the function boxes, but I cannot select them fast enough or it wont let me before it goes back by itself to the “select control Module screen. It is the same with any module I select.
How do I access these functions?
Options
Test COM port
01
03
17
33
3F
And 46.
