emperorpatrickiv
I have completed an auto to 6 speed manual swap. The car runs fine, but I am still getting a check engine light, and DTC's which indicate a couple of the modules are still looking for the TCM, even though I seem to have coded them correctly. I have followed all how-to's and fourm tips that I could find - mainly Boertje's guide, even the note which states to recode the CAN bus to 00006 even when it is already 00006 to force the module to look for the TCM and find that it is indeed gone. Of note, the only problems I am having now are the CEL, triggered by the DTC'S caused by the modules looking for the TCM, and the cruise cancel switch on the clutch not working. Below is the log from my Vag-Com. Any and all help is greatly appreciated.
Of note, the ABS code 01314 is new to this log. It was not showing up on previous scans during this troubleshooting process.
Sunday,18,December,2022,16:38:01:30934
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: 3VWSP69M31M195844 License Plate:
Mileage: 450610km-279996mi Repair Order:
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
Mileage: 450610km-279996miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 CP
Component: 1,9l R4 EDC G030SG 2839
Coding: 00002
Shop #: WSC 12345
VCID: 6099AC74F3542E6B8B2-4B3C
1 Fault Found:
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
Readiness: 1 1 1 1 1
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 12345 111 45799
VCID: 2A0D0E5CC0E8A43B956-5184
2 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
01315 - Transmission Control Module
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 04 AIRBAG VW6 0202 0004
Coding: 12340
Shop #: WSC 00066
VCID: 3A2D3E1C354814BBE56-4B3C
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 905 M
Component: A4-KOMBIINSTR. VDO V53
Coding: 07234
Shop #: WSC 12345
VCID: 313F1930E83ED7E354C-5160
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0A3472737
IMMO-IDENTNR: VWZ7Z0A3472737
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
VCID: 70B9DC3423B49EEB1B2-5160
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
VCID: 06559AEC3130A05BD1E-4B1E
Subsystem 1 - Part No: 1J1959801C
Component: 61 Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 61 Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 61 Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 61 Tõrsteuerger. HR0002r
Address 56: Radio Labels: 1J0-035-18x-56.clb
Part No: 1JM 035 157 A
Component: Radio DE2 0005
Coding: 02042
Shop #: WSC 00066
VCID: 3E25320C2960389BD9E-51F2
End----(Elapsed Time: 05:26, VBatt start/end: 11.6V/11.4V. VIgn 11.4V)-----
www.Ross-Tech.com
75 76
Coding: 00002
Shop #: WSC 12345
1 Fault Found:
Coding: 0001025
2 Faults Found:
Coding: 12340
Shop #: WSC 00066
Coding: 07234
Shop #: WSC 12345
Coding: 00006
Shop #: WSC 00066
Coding: 04096
Shop #: WSC 00066
Coding: 02042
Shop #: WSC 00066
