Erik Lupo 3L
- Joined
- Jun 26, 2002
- Location
- Denmark
My instrument cluster has gone haywire.
Pre history:
I had to loosen the dashboard to change my heater to one with A/C. Therefore I also removed the instrument cluster and the steering wheel. I am sure that at least the steering wheel was removed while the battery was disconnected. I also removed the floor carpeting to gain access to the firewall. The airbag controller is situated near the firewall, on top of the driveshaft tunnel, so I might have disturbed its connector and/or cables.
After reassembly, 4 or 5 warning lights come on, and Vag-Com lists the following error codes:
17 Instruments:
4 DTC's Found:
01314 - Engine Control Module
49-00 - No Communications
01315 - Transmission Control Module
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
These can not be reset.
The only other control module that has an error code is:
15 Airbag controller
1 DTC's Found:
01299 - Diagnostic Interface for Data Bus (J533)
This can be reset, but after checking 17 instrument again, the error code comes back.
How should I proceed?
Pre history:
17 Instruments:
4 DTC's Found:
1 DTC's Found:
