tobert
On my 2005 mk4 jetta the last week or so I have been having lots of trouble shifting the car into reverse. The other gears work fine, I can shift up shift down and it doesn't give me a second thought until I want to back up.
When I can get the car to decide it wants to go into reverse its solid. The clutch seems to work right and it has correct power etc.
The shifter feels like reverse doesn't even exist, no gear grinding or anything it just drops in when it decides it wants to. The last couple days I've had to really put some force behind it to get it into gear.
Because it goes and stays once its persuaded I don't think its an issue with the transmission itself, and since it doesn't try to grind I don't think its the synchros. I'm thinking tomorrow I'll go see if adjusting the shift linkage helps but I kind of doubt it. I'm suspecting (and hoping) its a worn out bushing or something but I'd love to hear from someone that might be able to point me in the right direction of what to look for or how to better diagnose this.
Some history on the car, its got 240k miles on the original clutch with a half shot DMF and was giving a little trouble finding 3rd gear and I'd occasionally miss and grind 3rd but after changing the fluid, its **otherwise** shifting fairly nicely. The clutch flywheel and chasing out the gremlins in the transmission are on the to-do list but the bank account says its going to be to-done around January and I'm hoping to be able to get there with it.
The transmission won't shift into reverse even when the shifter cables are loose, so the problem has to be either on the shift tower or **gulp** in the transmission. I've adjusted the shifter cables to no avail and suspect the part I posted a picture of came off the shifter cable as I can't imagine where else it'd have come from but I think thats another problem.
