Wildebeast
I was driving today and noticed my check engine light came on. I used OBD-11 to scan the car and got the following codes:
The dreaded P2002 code (DPF), P0401 (EGR upper limit exceeded), and P1A58 (Nox catalyst regen required. The DPF soot load is 21.6 g (calculated) and 5.1g (measured). Last regeneration occurred 270km ago. The particle filter differential pressure was measured at 10mbar. The offset differential was 0mbar.
Several weeks ago, I got the P2002 code. The dealer cleaned/regenerated the DPF and found an air leak in the turbo inlet pipe, which was replaced. I distrust VW, so I got a second opinion, and the DPF was in good condition two weeks hence. It has done one regeneration since then, and I took it on a long drive of about 100 miles last night.
I am not sure what to do. I am loathe to take it out for a regen cruise for fear of making all of this worse. VW recommends a nox catylist regen cruise and gives instructions on how to do that. However, there are multiple codes and a complex system so I don't want to **** things up further. The gross preponderance of the miles on this car is the freeway.
Any ideas aside from taking a hacksaw to the emissions crap and selling it for scrap?
The punch line is that the Diesel Gate warranty expired last week.
