79TA7.6
- Joined
- May 8, 2006
- TDI
- 2003 Jetta GLS 5 Speed
I have been playing around with the throttle while using cruise on my trips back and forth to work, 70 miles each way. If I leave my foot on the accelerator, 25% according to Torque, my mileage increases significantly according to Torque, which has been pretty accurate for the last 8 months. What I am contributing this to is that there are a LOT of hills on my travels, therefore I am able to gain more speed going down hill, building up speed for the uphill journey. I will be doing this for this entire tank to see if it really does help my mileage.
Now for my question. Is there a way that I can trick my CPU to thinking the throttle is at 25%? I would ONLY do this by supplying power from the CC somehow. My thought is to use a relay that would be powered by the CC, so when ever I have my CC set and turned on (actually working) it would power a relay where I would switch the power that is acting like the throttle. I would have a switch inline to manually deactivate it as well. The relay would kick out when the CC kicked out, when I deactivate it, hit the brakes, or push in the clutch. This would keep the engine from revving up on its own.
I am assuming the throttle is a rheostat of some sort, so I think I would be able to use a resister or something in order to get the correct signal. I am just not sure where I would plug this reduced power source into.
Am I out of my mind in thinking this is doable? I am sure there is the possibility of doing harm so what is it, besides smoking my CPU. Please do not flame or anything like that. I am not sure if I am even going to do this yet. If you have good reasons it should not be done, please state why. My life is all about the learning adventure, but if someone knows it will not work and can tell me why, then I do not need to find out for myself.
