52172
Anyone try running this oil in their alh? Seems its a quality oil along the lines of Schaefer oil except much better price?
oil analysis is used to determine an oils servicibility during a time/mileage interval and duty cycle. Its also a way to check for contamination. Wear Metals measured in PPM are only useful data for tracking wear trends.Theres been 3-4 oil analysis completed after 5,6, and 7 k miles and all were excellent. As good as schaefer.
An ALH is going to be perfectly content with any 5w40 you feed it. If the OP is happy w the Triax stuff, I see no need to piss in his Cheerios. Unless you're just of a disagreeable disposition.
100%
Elementary? Right, so you should understand that a single oil analysis at 5,6 or 7k is basically meaningless unless you’re looking for contamination. If you’re looking for trends, the data for years should be in an excel spreadsheet to find the “best” lubricant.Elementary
