The OP will be lucky if 5th gear hasn't been trashed. The 5th Gear set/assembly suffers first when the oil level goes down (search my Photo Albums).
I'm amazed that the bottom of the Transmission (and car) isn't loaded with a very sticky slick of oil....... where did it go?
I switched all of my manual shift vehicles to Synchromesh about three or four years ago.
The transmission in my 84 TDI Vanagon has almost 89k miles on it (I built it and put in service, 8/12). I also switched it to Synchromesh. Anyway, I am building a replacement transmission for it. I plan to use Synchromesh in it as well. So far, I have over $3,000 in parts ready for the build!
Anyway, rebuilding Bus and Vanagon transmissions and being inside a few TDI transmissions, I've not seen anything that looked like Synchros dissolving, corroding or rotting away. What I have seen is badly worn lands (grooves) on the Brass Synchro Ring that ride on the Gear Cone. I very seldom see worn teeth on the Synchro Ring. I do see worn teeth on the Cone where the Slider meshes as well as worn Slider teeth. Anyway, once those grooves on the Synchro Ring are worn down it no longer functions properly, thus raking/grinding when shifting. I suppose a heavier oil would help.
Lastly, a slightly dragging clutch disc for whatever reason can affect how well the transmission shifts.
Sorry I've asked so much about this but I just wanted to clarify somethings. I know you said to wash the transmission but I haven't bought a power washer yet. Now the leak, it's literally pouring out so much and I wanted to ask if it would be leaking anywhere else besides the shaft seals? I noticed a few different seals searching but are these the parts I would need for the job and would this fix my problem? I did replace the transmission gasket cover which was leaking as well.
Screenshot-20230423-050826-Chrome hosted at ImgBB
Image Screenshot-20230423-050826-Chrome hosted in ImgBBibb.coScreenshot-20230423-050746-Chrome hosted at ImgBB
Image Screenshot-20230423-050746-Chrome hosted in ImgBBibb.co
Also with the transmission going dry you mentioned the 5th gear may have been affected. Im sure the transmission is beat up a little bit but it's been over a year and still driving good. I guess once the oil is full there really is now issue with shifting.
The only thing that might be happening is when its parked at an incline it will want to knock when I put it in reverse but that could because the oil level is always falling and 2nd will grind a little if I put into gear too fast so I gently engage it if needed.
So the cover side will I be able to see any damage that may have occurred from this event and can I do any repairs? I've seen videos about replacing gears from there. What thicker gl4 is there. Just a higher weight? Really im wondering how long it will go or if any serious damage was caused.
