98JettaBioDiesel
Recently finished a complete engine rebuild on my 98 Jetta TDI (YIPEE).
Replaced clutch with Sachs unit, new TO bearing and output shaft/rear seal. Replaced trans fluid with 2qt Redline MTL.
The trans now makes a somewhat disconcerting rattling noise in neutral, which stops if I depress the clutch - about 1/2 way to the floor. Because of the amount of travel on the clutch pedal I get the feeling this isn't clutch/TO bearing related - plus the sound is wrong.
So I get the feeling it's internal trans parts (bearings - yikes?), but strangely increasing the RPM doesn't seem to change the pitch of the sound - so one of my car nut friends thinks it's more of a rattle.
Wondering if the different (thinner?) MTL fluid could be related, or if anyone out there is familiar with this condition???
