DHC
2005 Passat TDI, 170,000 km. My transmission is now in limp mode. When I read the code it is P0706. I know it is transmission range sensor circuit - range/performance. I searched here and found a few ideas but most of the threads were inconclusive.
I pulled up the carpet on passenger side and found it wet but not flooded. Opened the TCM black box and it was not wet inside. Dried carpet and wires but still the same problem. Even was able to try another TCM from a parts car and still get the same thing. Display is in reverse mode after it clunks into limp, but when first start the car P R and N display okay but not D or any numbers except 2 . If I start out in D it won't shift up until I pull it back to 4 and then it shifts to limp mode.
I am thinking it is the switch on the side of the transmission but would like to know for sure befor changinh as it is a big job and the switch is quite expensive.
