elcamino73
I finally got the trans out and new clutch/flywheel installed. Can't seem to get the trans back in; what tricks, etc do you use to get the 5-speed manual trans back in?
I'm about to remove the RH output shaft and try to slide on w/ transfer case at bottom then rotate, but if that doesn't work I'll need y'alls help!
Please post your tips, tricks, etc while I try and get this bugger in!
