Transmission ID help
Petesaguytdi
Edmonton. Alberta
2004 Bhw Passat
Got a 0A4 5spd transmission but the model code FP15 seems to be a unicorn. Any one seen this code before. It's supposed to be from a 2006 TDI Jetta.
Any insight is much appreciated.
Steve Addy
Iowa
97 Mk3
That's not your trans code...the code is found on the top of the trans near the starter area close to the mounting with the block. You shouldn't have a problem finding it, there's a machined flat surface where the code will be found.
If it's actually from an 06 TDI it's likely either a GQQ or an EUH. Any other code would lead me to speculate it's from a different year maybe.
Steve
Petesaguytdi
Edmonton. Alberta
2004 Bhw Passat
Thanks Steve, Ill take another look as the site I checked at said otherwise. I trust first hand experience in your case to be more accurate !
