Transmission A4 ALH
JonFord
Houston, Texas
2003 Jetta
I can't get into 1st gear. It is like something is blocking the linkage. All the other gears work fine and drive ok.
jettawreck
Northern Minnesota-55744
2001 Jetta and 2003 Jetta
Check out the cable adjustment and the condition of the shift tower bushings which can get very rough shape over time. Otherwise it may be internal on the selector "gear". If it gets even slightly burred up from a bad shift it won't allow the chosen gear to engage, it will feel "locked out". Not an easy fix, I've done one.
