mycruiseagent
Hey all,
I have an 02 Jetta that I did the .681 gear swap on way back in 2006. Just recently it started acting like a syncro was going.
Well, it turns out that's not what it was. The bolt in the center of the larger gear has backed itself out and wore through the trans end cover.
As a result I need a few replacement parts that I hope will get this trans going again.
1) the large M10 bolt (which chewed up its first few threads in the course of working loose)
2) all three of the little teeth/palls that go inside the selector gear (they look a little worse for the wear)
3) the two wire C-clips that hold the selector palls in place
4) the trans end cover
Your help with ETKA looking up part numbers would be appreciated.
TIA,
Mark
TIA,
Mark
