Tranny on shelf 2 yrs - what seals need replacing?
LeeM
Hagerstown,MD
2015 Passat SE, 2002 Jetta Reflex Silver
I have a used transmission that has been sitting around for two years. What seals should be replaced and is there any maintenance that should be done?
LeeM
Hagerstown,MD
It is a 6 speed DRW manual transmission with about 30,000 miles on it. I bought it two years ago from a used parts supplier who picked it up in Europe. I finally have all the parts I need to install it and would like it to be in the best possible shape when that happens.
wrenching40plus
Sparkle City, SC 29306
Jetta 2000 (given to bro-in-law)
If you are looking for the absolute 'best possible shape' you can think about sending it to a specialist rebuilder. If you want to keep things reasonable, then the key question will be: What does the existing fluid look like, when you drain it?? Assuming an OK on this, I would find a container large enough to hold the trans, pull any access covers, and let it soak in Diesel fuel or ATF for several days. If you see rust on a shaft at a seal you can deal with it... OTW just blow it clean, replace the covers, and install; then (of course) fill with fresh lube. AYMK this is a great time to think about your clutch, maybe re-surface the flywheel. How are you fixed for an engine support?
LeeM
Hagerstown,MD
For an engine support I will probably build something along the lines of what Herm designed using items easily accessible at a home improvement store. Herm-o-hanger
