Trailer wiring?
bonktz71
Marion, Alabama
2011 Jetta TDI
I'm getting a Curt hitch for my TDI. Do I really NEED the wiring that goes to the battery or will the kit without the battery wiring work?
TDIx2
Saginaw Mi ~ looking out for deer and dangerous pe
2014 Jetta
Not going to work without power. However if you don't want to run wire to your fuse panel or battery there is a way around this.
I bought a power plug and connected it to the ground and power leads on the curt unit. When I tow I simply pull it across the rear seat a plug it in to the rear console. I realize this may not be the best way to complete the circuit but for the five to eight times a year I tow the trailer this set up has been flawless.
