JaredC01
As most of you know, the Mk VI Jetta doesn't come with any form of traction control disabling options. A member on another forum figured out how to add one to his Mk VI GLI, and posted the details. As it so happens, the same technique works for the TDI!
Anyway, on to the good news... I got mine installed this evening, and took quite a few pics along the way. The bad news, is that I ran out of daylight and didn't take as many as I would have liked to take. I also ran into a snag that anyone else preparing to do this mod should take note of.
On to business...
I started off following the instructions listed HERE. The instructions are pretty generic as far as the button is concerned, so I hope to at least shed a bit of light on that part of the install.
The parts came in a small package, all the way from Hong Kong!
Up close on the button... Good quality, if not OEM it's a very good replica.
Bold-Sport harness... You'll notice there are some extra wires coming out that AREN'T in a connector, they go into the empty connector. This is also where I got my connector for the next picture...
Modified harness (extra wires / connector removed). The right end in the picture plugs into the switch, and has had the red cover removed.
*NOTE* The Bold-Sport harness had pins 5 and 6 REVERSED in this picture! The Orange wire should be in position 5, and the Black wire should be in position 6! *NOTE*
Extension wires added to the removed connector.
Factory TPS switch plug (red cover removed here as well) with tape removed to expose wires.
Wires from extension soldered onto the factory TPS wiring.
Soldered wires heat-shrunk (removed pins from factory TPS harness to slide heat shrink over).
Whole harness wrapped in cloth tape (highly recommend this stuff BTW)...
continued...
On to business...
continued...
