Well, no one had done a stock '01 ECM and ASR. So today I tried. I have a 'CP' ECM and installed a used 1C0 907 379 K. Soft coding is 0021505. First contact showed 2 fault codes. 1 for the right front ABS sensor, and one for ECM code. Tried clearing and it wouldn't. Went to adaptation group 00, read, save, then back to the fault codes. They cleared.
Went through the bleeding process, put the wheels back on, and went for a test.
Found a place with gravel surface sure to make for loss of traction.
Hit the go pedal from a dead stop.
Called Lito and asked what the flashing triangle with ! and circular arrow around it meant.
Yes, folks a 2001 with stock ECM and Mk. 60 can have ASR!
Also note that I have an auto tranny so that adds a TCM to the mix.
