turbocharged798
I tried to contact you about it, but have no contact info. I can't even email you as the fourms won't let me see your email.
Anyway, I found an ASR switch for $12 off vortex.
Now it was mentioned that 00 and up that the light in the dash will work right off with no wiring. The reason is because of can-bus. It simply communicates with the cluster via the can-bus. 99.5's do not have can bus so the light does not work, but you can make it work by connecting a wire from the ABS unit to the cluster. Some of you probably already knew that, but I just wanted to make that clear as there seems to be a lot of confusion about it. I know as a fact that the 99.5's do have a light in there. It just doesn't work because it has nothing to complete the circuit.
So, I will need to run a wire from pin 15 in the ABS unit, to pin 14 in green connector behind the cluster. Then I will need to branch off that line and go to pin 5 in the ASR switch. Pin 6 in the switch goes to B+(I will steal that from the defrost switch). Pin 2 goes to ground and pin 1 goes to the dash lights.(again, I will take that off the defrost switch as well.)
Of course, this is all coming from my Bentley so if there is an error in there, this will have an error as well.
If I get time, I will write up a easy to understand 99.5 wiring diagram.
